Topics
Author
Replies
Views
Last Post
Announcements
Welcome!
DrJustice
3
3869
Tue Jan 29, 2008 1:55 pm
DrJustice
Topics
How to Choose the right Capacitor
21
12850
Mon May 20, 2013 5:36 am
Adolf Christus
DSP Algorithm Libraries
List your open source libraries of C, Assembler, etc. here
7
4250
Wed Apr 21, 2010 8:03 pm
slugger
9v single supply Simple LM741 Triangle LFO: CV possible??
works on breadboard (with video)
Adolf Christus
2
160
Yesterday, at 2:33 pm
Adolf Christus
Voltage controlled counter or 1-to-8-multiplexer?
Is there some chip, that converts a varying input voltage to multiple output hi/lo?
[ Goto page:
1 , 2 ]
Adolf Christus
33
1257
Yesterday, at 1:12 am
L´Andratté
The Jerkster -
questions and thoughts
L´Andratté
3
178
Mon May 20, 2013 8:47 pm
Simple CV sequencer with external clock control
rogerlatur
2
127
Mon May 20, 2013 5:35 pm
Sallen Key vactrol filter values
Rolbista
4
303
Mon May 20, 2013 12:32 pm
Rolbista
CMOS synth etc problem with heterodyne mixed output-probably
built synth worked fine, then decided, since 40106 had enough pins to double it and use heterody
new voodoo
0
57
Mon May 20, 2013 8:18 am
new voodoo
2k Tempco advice
Options to replace 2k tempco
ejr27233
6
1411
Mon May 20, 2013 6:29 am
L´Andratté
Stereo delay / Vibrato
[ Goto page:
1 , 2 , 3 ]
papaver
54
5024
Thu May 16, 2013 6:00 am
Paradigm X
battery powered mini-mini-minimalist op amp sample & hold
will this really work like on falstad simulator (with link) ???
Adolf Christus
3
222
Mon May 13, 2013 11:14 pm
johncronan
LM13700 VCA and other circuits
alkopop79
1
181
Mon May 13, 2013 7:45 am
richardc64
Most simple VCF on earth
[ Goto page:
1 , 2 ]
metal_head_82
37
13394
Fri May 10, 2013 10:27 pm
Single Op Amp SAW VCO
It actually works!!!
metal_head_82
21
7965
Thu May 09, 2013 4:09 pm
Adolf Christus
KORG Minipops 120 Easy Sync Out Mod
You can do it!
L´Andratté
2
537
Wed Apr 24, 2013 12:33 am
NoizeToyz
9V battery project to Buchla module project
Using GND a Minus?
rogerlatur
2
426
Sun Apr 14, 2013 10:57 am
rogerlatur
CS-80 style VCO
elektrouwe
1
370
Sun Mar 31, 2013 2:30 am
steffensen
What's Uncle Krunkus up to now?
5501
Fri Mar 29, 2013 5:36 pm
analog_backlash
Germanium Transistor opamp with FET
paulmorison
0
274
Fri Mar 22, 2013 1:30 am
paulmorison
synthesizer trio
uuuuu
24
2265
Thu Mar 07, 2013 3:59 pm
analog_backlash
Any simple bass drum schematic? or snare?
wahoah
14
1847
Wed Mar 06, 2013 6:58 pm
EATyourGuitar
Square wave to sawtooth converter
picsynth
8
5117
Wed Mar 06, 2013 9:52 am
Rolbista
Q: Switch btw jack + speaker / shared volume LDR
darematheson
8
615
Tue Mar 05, 2013 9:06 am
analog_backlash
"Scanner" Sequencer
16 Steps Bass Drum Trigger Sequencer
KRS1972
7
1294
Mon Mar 04, 2013 3:03 pm
L´Andratté
relaxation makes an interesting square
EATyourGuitar
0
238
Sun Mar 03, 2013 12:28 pm
EATyourGuitar
TEST'O'CASE
Breadboard flightcase DeluXe
KRS1972
0
221
Thu Feb 28, 2013 2:52 pm
KRS1972
momentary switch gate send ideas...
marcelds
1
298
Wed Feb 27, 2013 5:50 pm
DrJustice
Any tips or schematics for building an advanced LFO?
Hedefar
15
1511
Sun Feb 24, 2013 6:25 pm
johncronan
12 db high pass problems. Help needed
the19thbear
9
929
Wed Feb 20, 2013 1:27 am
the19thbear
Drum Module Triggering ?
From Drum Machine Aux outputs
tasteless
3
368
Mon Feb 18, 2013 11:54 pm
tasteless
generator env
blackyellow
6
673
Thu Feb 14, 2013 5:37 am
prgdeltablues
Tone-Differential Chorus
Equal-Temperament's latent built-in chorus
Tony Deff
5
928
Wed Feb 13, 2013 3:59 pm
Tony Deff
How to start
NathanJ
8
1045
Wed Feb 13, 2013 9:15 am
Hedefar
Simple DIY dsPIC Project
A blog of a Simple DIY dsPIC Project
[ Goto page:
1 , 2 , 3 , 4 , 5 ]
JovianPyx
109
27140
Tue Feb 12, 2013 3:59 pm
JovianPyx
Programmable Divider with Pseudo-Square output
9-bit switch-programmable division retains duty cycle ≈ 50%. Top-Octave Generator note replacement
Tony Deff
2
891
Sun Feb 03, 2013 8:48 am
Tony Deff
Question about fm implementation for ota filter
L´Andratté
4
417
Tue Jan 29, 2013 7:04 pm
L´Andratté
SOLVED: EAGLE users? I'm trying to generate parts lists...
Dougster
3
810
Tue Jan 29, 2013 3:20 am
mahjo
Moog VCF - Resonance, Voltage Control of ?
unshaven
4
663
Sun Jan 27, 2013 1:37 pm
unshaven
Simple mixing techniques for 40106/op amp oscillators
Why am I getting chaos nasties instead of chords?
Werebear
13
1737
Wed Jan 23, 2013 1:26 pm
Werebear
CV > MIDI Clock > CV
MoltenVoltage
2
518
Sun Jan 13, 2013 9:12 pm
MoltenVoltage
Switch mode power supply and virtual ground
mrkva
2
465
Sat Jan 12, 2013 9:19 am
mrkva
Incredibly Low Output from POS Vactrol Gate
yoga4dogs
0
330
Wed Jan 02, 2013 10:19 pm
yoga4dogs
Questions about filter design
acidblue
23
2244
Thu Dec 27, 2012 2:24 pm
Dougster
3x8 Step Gate/Trigger Sequencer
4017 based sequencer, gate to trigger converter, 555 clock generator and electronic switch
KRS1972
22
3974
Sun Dec 16, 2012 9:11 am
david.tb303
Some good programming and quality control Advice
A Shuttle Failure Averted
539
Tue Dec 11, 2012 9:22 am
JovianPyx
Sever IC power?
darematheson
3
794
Sun Dec 02, 2012 7:23 pm
darematheson
Furniture bending. Ideas on how to use existing furniture as
HansRL
3
706
Sat Nov 24, 2012 3:51 pm
HansRL
Relabeled parts
HansRL
2
853
Tue Nov 20, 2012 4:07 am
HansRL
Matsushita Delay Line EFD-EN645
any info about this ic??
axl
5
1182
Fri Nov 09, 2012 11:17 am
cloudscapes
CCD based delay?
thoughts...
willi
15
3563
Thu Nov 08, 2012 5:12 pm
axl
Display topics from previous: All Topics 1 Day 7 Days 2 Weeks 1 Month 3 Months 6 Months 1 Year
Sort by: Last Post First Post Topic Title Replies Views Author
Ascending Descending
