 Forum index » Instruments and Equipment » Waldorf
Poorly Microwave XT
Page 1 of 1 [7 Posts]
Audio files: 150
PostPosted: Mon Mar 27, 2006 4:37 am    Post subject: Poorly Microwave XT Reply with quote  Mark this post and the followings unread
My XT is not very well at the moment, there is an intermittent problem with the main output. The sound suffers from a rhythmic gating effect which speeds up and slows down. This comes and goes, mostly after the XT has been on for a while. I'll upload an mp3 later.
Just wondered if anyone else had had a similar problem and knew what it might be.
Also, I'm taking this to my friendly electronics repair man and wondered if anyone knew if the schematics are available anywhere, just in case.
music | adventures in sound
Mohoyoho
PostPosted: Mon Mar 27, 2006 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to hear that. Can you try another power supply?
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Audio files: 150
PostPosted: Mon Mar 27, 2006 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if I have anything similar - I'll have a look
do you think this could be the cause of the problem?
Mohoyoho
PostPosted: Mon Mar 27, 2006 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
It's possible. I'm just guessing because you mention that it takes time for the problem to occur, and the power supply is one element that heats up over time. Also, it seems that when voltages aren't right, things might work, but become faulty.
Mark Mahoney
Audio files: 150
PostPosted: Mon Mar 27, 2006 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's interesting you say this, as I've been using a slightly different power supply for some time, as the old one died a while back.
I'm seeing if I can get the proper psu fixed to see if that will help.
Thanks for the advice Smile
Audio files: 150
PostPosted: Mon Apr 03, 2006 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Got the old psu fixed and it seems to have done the job Smile
Mohoyoho
PostPosted: Mon Apr 03, 2006 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Great. I've dusted off my XT and replaced my Q rack with it for live performance. It produces such great and unusual sounds. The main reason I replaced the Q was it was acting kind of funny. Sometimes a few presets wouldn't play unless I turned the rack on and off. Sometimes step sequences would begin with some noise and chatter. I felt I couldn't trust it for performance. So now I'm reacquainting myself with the XT.
Mark Mahoney
Niio1
