 Forum index » Instruments and Equipment » Waldorf
Waldorf XT problem
Page 1 of 1 [7 Posts]
chris73
PostPosted: Wed Nov 01, 2006 7:32 am    Post subject: Waldorf XT problem
Subject description: cant update yje OS?
I just bought a Waldorf XT, I am trying to update the OS (from 2.11 to 2.26) but it just wont work? Is there any way to reset the synth to factory default or something? I figured I might try that first before I update it.
Regards/Chris
Mohoyoho
PostPosted: Wed Nov 01, 2006 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
What are you using to load the file OS file in with? I find MidiOX the absolute best at this. Your typical sequencer software can work but sometimes there are sysex filters and what not that make it difficult.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
chris73
PostPosted: Wed Nov 01, 2006 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I use Cubase SX, I acctually tried MIDIox but I couldnt figure it out how to configure it and load the OS into the XT. Ill try that again but just incase, is there any factory reset feature?
Mohoyoho
PostPosted: Wed Nov 01, 2006 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't believe there is.
When using a sequencer, make sure you have the bps fairly low; 80ish.
In MidiOx you may have to expand the buffer.
I remember having a hard time loading an OS into my XT (or was it my Q) and not being able to do it with Sonar. As soon as I went to MidiOX it loaded effortlessly (after I struggled to figure out the setup.) If my memory serves me correctly, you also have to have the Midi Out and Midi In hooked between the XT and the computer.
You might want to experiment first by outputting presets from the XT to your sequencer and then vice versa. That will tell you if there is some communication from the synth to the computer.
Mark Mahoney
Mohoyoho
PostPosted: Wed Nov 01, 2006 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I also was wondering if perhaps you are making too big of a jump from one OS to the next. I could be wrong. You might want to try the next OS up from what you have and see if that will load.
Mark Mahoney
chris73
PostPosted: Sat Nov 04, 2006 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally! It worked, I took time and worked a bit more with MIDIOX and it was a fast thing upgrading from 2.11 to 2.33. Thanks a lot for the tip! =)
Mohoyoho
PostPosted: Sat Nov 04, 2006 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad it worked out. MidiOx is quite good. Now go and enjoy that XT! Make some music.
Mark Mahoney
