Casting time or dur to a float or int.
Page 1 of 1 [2 Posts]
jbum
PostPosted: Sat Nov 04, 2006 12:04 am    Post subject: Casting time or dur to a float or int. Reply with quote  Mark this post and the followings unread
I'd like to be able to compute a parameter for Math.sin() that is based on the passage of time, but thus far, my attempts to put times or durations into floats or ints haven't worked.
Is there a way to do something like this?
Code:
SinOsc voc => dac;
now => time startTime;
// time elapses...
now - startTime => dur elapsed;
// THIS IS THE PROBLEM LINE...
(Math.sin(Math.pow(elapsed,2)) *1000 + 20) => voc.freq;
I realize I can accomplish this using a SinOsc instead of Math.sin, but nonetheless, it would be nice to be able to use time as a parameter for Math functions...
<a href="http://www.krazydad.com/">krazydad.com</a>
<a href="http://www.coverpop.com/">coverpop.com</a>
ge
PostPosted: Sat Nov 04, 2006 2:36 am    Post subject: Re: Casting time or dur to a float or int. Reply with quote  Mark this post and the followings unread
Sure can, I think. It's all about making the unit come out. Just divide the duration or even time value by any duration, and get the result as float.
Code:
Math.sin(Math.pow(elapsed/ms, 2)) => ...
One can also compute the sample rate this way.
Code:
 <<< "sample rate:", second/samp >>>;
Hope this helps.
Ge!
Buy N Save
