jbum
Posted: Tue Oct 31, 2006 2:57 pm Post subject:
Whitney Music Box Subject description: Some sample ChucK source code for producing this piece. |
Hi Folks,
Thought you might like some sample ChucK code for playing with the Whitney Music Box algorithm. Here it is.
http://www.coverpop.com/whitney/whitney.ck.html
For a visualization of what is going on, check this link:
| Code: |
// Whitney Music Box
// Jim Bumgardner jbum@jbum.com
48 => int nbrDots;
55 => float baseFreq;
180 => float durationOfPiece;
2.0/nbrDots => float dotGain;
fun void whitneyDot(float baseFreq, float secs, int nDots)
StifKarp voc => dac;
dotGain => voc.gain;
for (0 => int i; i < nDots; ++i)
baseFreq => voc.freq;
1 => voc.noteOn;
secs::second => now;
1 => voc.noteOff;
// Sample Chromatic Pitch Function
fun float pitchFuncC(float baseFreq, int noteIdx)
return baseFreq*Math.pow(2,noteIdx/12.0);
// Sample Reversed Harmonics Pitch Function
fun float pitchFuncH(float baseFreq, int noteIdx)
return baseFreq*(nbrDots-noteIdx);
for (0 => int i; i < nbrDots; ++i)
spork ~ whitneyDot(pitchFuncC(baseFreq,i), durationOfPiece/(i+1), i+1);
durationOfPiece::second => now;
_________________ <a href="http://www.krazydad.com/">krazydad.com</a>
<a href="http://www.coverpop.com/">coverpop.com</a> |
jbum
Posted: Wed Nov 01, 2006 4:22 pm Post subject:
Here's an alternate version which uses a SinOsc with a pluck-like envelope, and which uses more dots and harmonic pitches.
Note: I'm wishing there was a built-in ugen in ChucK for producing non-linear envelopes ala the CSound linen function - it would greatly simplify or eliminate the playNote() function in this code.
This version is nearly fast enough for real-time on my computer (unlike the last version).
| Code: |
// Whitney Music Box - sine waves with pluckish envelope
120 => int nbrDots;
20 => float baseFreq;
fun void playNote(float freq, float amp)
SinOsc voc => dac;
freq => voc.freq;
1 => int attack;
1/65536.0 => float myGain;
myGain => voc.gain;
while (attack || myGain > .001)
10::ms => now;
if (attack) {
myGain*1.25 => myGain => voc.gain;
if (myGain >= amp) {
0 => attack;
else {
myGain*.99 => myGain => voc.gain;
spork ~ playNote(baseFreq, dotGain);
spork ~ whitneyDot(pitchFuncH(baseFreq,i), durationOfPiece/(i+1), i+1);
majutsu
Joined: Jun 18, 2006 Posts: 142 Location: louisiana usa
Posted: Wed Nov 01, 2006 4:27 pm Post subject:
thanks for sharing
interesting _________________ All phenomena are atoms in association and dissociation. |
jbum
Posted: Fri Nov 03, 2006 9:41 pm Post subject:
I posted a couple new Whitney Box variations in which I used ChucK to generate the sound.
http://www.coverpop.com/whitney/forums.html?var=v19
http://www.coverpop.com/whitney/forums.html?var=v20
For the stereo variation, I recorded the dac.left and dac.right channels separately. I haven't figured out a way to record in stereo directly to WvOut. _________________ <a href="http://www.krazydad.com/">krazydad.com</a>
cebec
Joined: Apr 19, 2004 Posts: 960 Location: Alexandria, VA
G2 patch files: 31
Posted: Sun Nov 05, 2006 1:48 pm Post subject:
| cool stuff! |
