 Forum index » Instruments and Equipment » Linux as a music workstation
Rosegarden
Page 1 of 1 [5 Posts]
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Fri May 04, 2007 1:00 pm    Post subject: Rosegarden
Subject description: anyone used this/heard about this?
it's a DAW for linux. just installed it, looks pretty conventional but can't get audio to work...
i'm messing around on my friend's linux machine.
there's no I in TEAM, so let's all act as individuals instead
EdisonRex
Audio files: 168
PostPosted: Fri May 04, 2007 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rosegarden wants the ALSA sound system, none other. Which is the sound system you are using?
Garret: It's so retro.
PostPosted: Fri May 04, 2007 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might want to check out ze new Ardour 2.0 too. I dunno how it compares to Rosie though.
Flickr
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Sun May 06, 2007 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
the error message says:
Rosegarden was unable to find a high-resolution timing source for MIDI performance.
This may mean you are using a Linux system with the kernel timer resolution set too low. Please contact your Linux distributor for more information.
my friend's computer is using ALSA, but the soundcard is an SBLIVE! Value... but i would have thought that the timing source would be related to the CPU and not the soundcard. any thoughts?
EdisonRex
Audio files: 168
PostPosted: Sun May 06, 2007 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, try downloading and installing The Jack Audio Connection Kit from http://jackaudio.org/
I think that might do it for you. Otherwise, getting the kernel to do -rt is a bit more of a chore.
