TX-1 power supply question
Page 1 of 1 [2 Posts]
Axiom
G2 patch files: 28
PostPosted: Sat Mar 10, 2007 7:16 am    Post subject: TX-1 power supply question Reply with quote  Mark this post and the followings unread
Hi folks,
today i've got a TX-1 to review but the power supply trasformer is 110V (with US plug type). I should buy a power converter or I can use another kind of wallwart?
Luca
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
EdisonRex
Audio files: 168
PostPosted: Sat Mar 10, 2007 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, Luca.
TX-1 User Manual wrote:
Use the one that CAME WITH THE AGONIZER. The Agonizer needs 10v to 12v AC power ONLY. DC will damage it, suckboy.
You must feed 12 volts AC into Metasonix equipment. There are virtually no "wall wart" supplies that put out adequate AC power, which is why the manuals recommend (no, insist, even threaten) that you use only 12VAC supplies.
Now, if you were handy with both electrical hardware catalogs and electrical things, and understand AC from DC, you would source a proper 12V AC supply (proper transformers are available) and wire it properly. But if you don't get it right, it won't be good for the TX-1.
Best bet is a stepdown transformer. You don't need a very big one for something as small as the TX-1.
Garret: It's so retro.
Niio1
