 Forum index » News... » Gear News
M-Audio Firewire Audiophile interface
Page 1 of 1 [23 Posts]
PostPosted: Sun Jan 04, 2004 2:29 pm    Post subject: M-Audio Firewire Audiophile interface Reply with quote  Mark this post and the followings unread
This one looks like a decent device!
Pretty OK specs. I recently got the Firewire 410, and that one has proved to be excellent.
FireWire Audiophile is a compact, FireWire-compatible audio/MIDI interface that takes the legacy of M-Audio’s award-winning Audiophile line to the next level. 4 x 6 audio I/O combines with powerful on-board mixing in a mobile package that’s perfect for live performance, home recording, and digital DJ work. Stereo headphone output with A/B switching between assignable sources allows precuing for DJs and mobile musicians—and the assignable aux bus is perfect for creating dedicated headphone mixes and effect sends. You also get zero-latency hardware direct monitoring, ultra-low latency ASIO software direct monitoring, and 1 x 1 MIDI I/O. FireWire Audiophile even has AC-3 and DTS passthrough for surround sound playback.
4 x 6 24-bit/96kHz I/O
S/PDIF digital I/O w/ PCM, AC-3, and DTS support
flexible software-controlled mixing
momentary A/B source monitoring switch
1 x 1 16-channel MIDI I/O
USD 349.95 MRSP
2 x 4 analog operation (RCA)
digital S/PDIF (coaxial) I/O w/ 2-channel PCM
digital out also supports AC-3/DTS surround sound
headphone output with dedicated level control
flexible software-controlled mixing of hardware and software I/O
aux sends on all channels and aux output assign allows for dedicated headphone mixes and sends to external effects
user-assignable front-panel level control (output, input, software return, aux send)
low-latency ASIO software direct monitoring
momentary switch for A/Bing two software-assignable headphone sources or switching ASIO monitoring on/off
power on/off switch with indicator LED
powered via FireWire bus* or included DC power supply
two convenient high-bandwidth FireWire ports
rugged steel construction
*requires 6-pin connection
frequency response:
20Hz-40kHz +/-0.40dB, 96kHz sample rate
dynamic range:
108dB A-weighted
 signal-to-noise:
106dB A-weighted
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Jan 04, 2004 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you talking to me Question
what's this Question poor people version of Firewire 410 Question
no phantom power Exclamation
you know I only use large diaphragm condenser mics Shocked
PostPosted: Sun Jan 04, 2004 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
No.. hehe.. I know you do.. and yes.. this is a kinda budget version of the excellent Firewire 410.
BTW: The Røde mics performed pretty OK with the 410. I cannot complain. Very Happy
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Jan 04, 2004 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Røde or Roede microphones Question
PostPosted: Sun Jan 04, 2004 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, obviously the Grete Roede mics are embedded in immense layers of fat? Jabba the Hut mics?
Nah... Røde it is!
Flickr
Audio files: 125
PostPosted: Sun Jan 04, 2004 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why only large diaphram mics? I thought large diaphram meant phase inaccuracies traded off for low frequency sensitivity.
Guest
PostPosted: Sun Jan 04, 2004 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
not neccessarily.... the nuemann u 87 has exquisite high end ..
some cheaper mics have a peak above 4k to add emphasis to the 'fairy dust' freq'as at 10k which is a less ideal solution and may lead to some of those phasing issues...
and, if by 'phase inaccuracies'you mean 'off axis phase', then any decent large diaphragm rejects these freq's
paul e.
PostPosted: Sun Jan 04, 2004 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
that last post was from me...auto log does not work for me if i don;t enter in at the index page
Audio files: 125
PostPosted: Sun Jan 04, 2004 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I was spooked by the Guest posting because these are supposed to be disallowed. Apparently, the new sub forums needed to be explicitly set up that way.
As for the small diaphrams: I know someone who writes lots of papers for AES about localization of sound in 3 dimensions. Some of the stuff he uses are binaural-like recordings called ambiophonic recordings. To get accurate localization, you need very good phase accuracy. This isn't frequency response. To get very good phase accuracy, the smaller diaphrams are required.
I'm not implying that large diaphram mics sound bad. I was just wondering why one would use them exclusively. I have mostly large diaphram mics because I don't spend a lot of money for mics. There is the point of diminishing returns. These discussions get similar to religious ones. Laughing
paul e.
PostPosted: Sun Jan 04, 2004 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i see what you mean by 'localization'..and yes this would be a problem for large diaphram mics
thre is of course the soundfield 5.1 mic.. i bet that would be sweet, eh
Audio files: 125
PostPosted: Sun Jan 04, 2004 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I'm real familiar with that one. It's useful for another technique called ambisonic sound. My friend, Robin Miller, has one of these babies, but for his work, these are not accurate enough.
PostPosted: Mon Jan 05, 2004 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, well.. large diaphram mics are often very prone to the proximity effect too, but many of the inexpensive ones are still pretty good.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Jan 05, 2004 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a couple of AKG C414 B-ULS with whom I have recorded many different intruments from cello to female voice always with excellent results.
I also have a great Neumann KM105 (that's not a large diaphram condenser, though) that's lovely Exclamation It's good not only in the studio but also for the stage.
(the C414 are also rugged enough to be used on live settings)
beat amateur
PostPosted: Mon Jan 05, 2004 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I will say that I recently purchased the PCI Audiophile 2496 rather than the firewire. It was incredibly easy to install and as mentioned above does provide the phantom power needed for my vocal recording goals. Looks like the firewire Audiophile might be good for certain applications but I wouldn't hesitate to recommend the PCI Audiophile.
paul e.
PostPosted: Mon Jan 05, 2004 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
-- beat amatuer
hello from toronto.... to you all in 'the hammer' ;]
beat amateur
PostPosted: Tue Jan 06, 2004 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, it's good to be here! Since it isn't always convenient to visit TO it's nice to have this forum as a way to build community with fellow electronic artists.
Checkin' out your tracks...
paul e.
PostPosted: Tue Jan 06, 2004 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
one of the better sites for electronic music is the webpage of the toronto radio show Feedback Monitor [89.5 CIUT FM]
greg clow, the host, keeps a great database of live shows in and around the GTA, and is also affiliated with the ambient ping website as well, as well as the new release section of http://www.brainwashed.com
check it out and listen online if you can
http://www.feedbackmonitor.com
[actually, mosc may want to add this to the links area [
Audio files: 125
PostPosted: Tue Jan 06, 2004 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sudden, you can add the link yourself. Just click on "links" and you'll see an add link option.
paul e.
PostPosted: Tue Jan 06, 2004 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
excellent... i added the link as you suggested
Audio files: 125
PostPosted: Wed Jan 07, 2004 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Great, thanks...
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Mar 19, 2004 9:06 am    Post subject: Re: M-Audio Firewire Audiophile interface Reply with quote  Mark this post and the followings unread
Jason Halbert wrote:
“Now I’m running Live with M-Audio’s FireWire 410,” says Halbert. “And just this last week I asked the crew to keep continuous power during a show, but one of the guys messed up and I lost power. But with the 410 being bus powered, I was able to still get it up and running in time to make the commercial break and not have to worry about re-booting the computer or anything like that. Bus power also means that I don't have to wait for the crew to set up, or run power before I can start getting things going. So I'm already running all the sound loops before they even get things set up. And sonically it’s great."
http://www.ableton.com/forums.html?main=artists?=jasonhalbert
PostPosted: Sat Mar 20, 2004 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sound On Sound ( http://sospubs.co.uk )
They have published a very nice review of the Firewire-410.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Mar 20, 2004 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sound On Sound ( http://www.sospubs.co.uk )
