About the sequencer too
Page 1 of 1 [9 Posts]
Tool
PostPosted: Sat Mar 24, 2007 8:25 pm    Post subject: About the sequencer too Reply with quote  Mark this post and the followings unread
Hi... another question with the sequencer...
what i am looking for now is to connect, for example, three sequencer modules in serial, but i want the first one repeat three times and then go to the second which repeat twice and then the third module 6 times and finish...
Is that possible? Thanks again
i dont know if i express myself very well (my english is not good)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sat Mar 24, 2007 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is one way of doing it.
The block in red creates a control signal which connects to one of the three main sequencers. The delay is required to stop false triggering due to logic 'racing'. Can be extended to 8 sequencers/16 bars as is, or more with extra modules. You need to push run to start sequence. Smile
chain3.pch2
 Filename:  chain3.pch2
 Filesize:  2.54 KB
 Downloaded:  666 Time(s)
Tool
PostPosted: Sun Mar 25, 2007 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok thank u very much....
I dont understand very well why u use the delay but I am going to connect my g2 and try this...
Wink
Tool
PostPosted: Sun Mar 25, 2007 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, definitly I dont understand why u use a delay in the red block... Can u explain me that if u have time? Thanks... I am a new user of the G2 and my brain is confused Razz
slave to this
G2 patch files: 7
PostPosted: Sun Mar 25, 2007 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a little bit different way of doing it.
your english is not so bad.
james
seqtrick.pch2
 Filename:  seqtrick.pch2
 Filesize:  2.14 KB
 Downloaded:  550 Time(s)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sun Mar 25, 2007 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
If you take the delay away, it still works, but each of the 3 sequencers gives one extra repeat at the same time as the next sequence starts. This sort of annoying glitch is common when using clocked logic/sequencers. In this case, the first thing I did was to delay (very slightly) one of the logic signal edges which fixed the glitch. It may be that just shifting the modules around stops the glitch, please feel free to experiment.
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sun Mar 25, 2007 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
That's very good, except for the sequencers all rest with the first step active. Which may or may not be a problem if you combine the sequencer outputs to drive a single destination.
slave to this
G2 patch files: 7
PostPosted: Sun Mar 25, 2007 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah, i didn't even notice. that's what i get for patching upon first waking up.
james
slave to this
G2 patch files: 7
PostPosted: Thu Mar 29, 2007 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
fixed.
fixedseqtrick.pch2
 Filename:  fixedseqtrick.pch2
 Filesize:  2.34 KB
 Downloaded:  599 Time(s)
