  Twyndyllyngs Live from Howard's! Chez Mosc
MIDI Learn Functionality
Page 1 of 1 [5 Posts]
clembie
PostPosted: Fri May 18, 2007 12:46 pm    Post subject: MIDI Learn Functionality
Subject description: Implementing a MIDI learn function as part of a patch
Confession: I'm both new to Chuck as well as being a novice programmer. Smile
I'm trying to build a(n exceptionally un-sexy) patch in ChucK to dynamically route signals from my MIDI controller to a PODxt (if you don't know, don't worry; It's a guitar gadget), whose parameters can be controlled via MIDI signals, but whose physical interface is complete shite.
The PODxt both receives as well as sends MIDI signals, so I want my patch to listen for signals from both. The PODxt MIDI signals will be used to verify that control is successful (nevermind that for now), but also, when the patch is in "learn" mode, indicate which parameter should be mapped to which controller parameter so all the performer has to do is:
- initiate learn mode
- indicate which parameter is being mapped by moving it on the PODxt
- indicate which controller is mapping to it by moving the controller
- exit learn mode
I'm going to keep a mapping table (probably a multi-dimensional array?) for map state, and learn-mode should be able to alter this table.
Here's where I'm stuck:
Code:
MidiIn cntrlmin;
MidiIn podxtin;
MidiOut podxtout;
MidiMsg msg;
1 => int cntrlinport;    // port in from controller
2 => int podxtinport;   // port in from pod
1 => int podxtportout;   // port out to PODxt
1 => int debug;         // turn on lots of string printing
// insert some sort of mapping table here...
false => int MACHINE_IS_LEARNING;
if( !cntrlmin.open(cntrlinport) ) { me.exit; }
if( !podxtin.open(podxtinport) ) { me.exit; }
if( !podxtout.open(podxtportout) ) { me.exit; }
// learn function
fun int machineLearn () {
    while( MACHINE_IS_LEARNING ) {
        // get PODxt parameter (data2) to map to
   // get controller (data2) to map from
   // update mapping table
   false => MACHINE_IS_LEARNING;  // get out, we're done
    // if successful, return 0, else return 1
while( true ) {
    cntrlmin => now;
    while( cntrlmin.recv(msg) ) {
        if( debug == 1 ) { <<<"Received msg: ",msg.data1,msg.data2,msg.data3>>>; }
        if( (msg.data1 == 144) && (msg.data2 == 36) ) {
             true => MACHINE_IS_LEARNING;
        // from here we have to go to some MIDI learn function
        // like machineLearn(), above...  But I keep crashing Chuck!
   // based on mapping table, change msg.data2 to appropriate
        podxtout.send(msg);
I'm ready to hear that I'm just too much of a noob to be writing state machines. Smile But I'm not sure whether I'm supposed to be making a function call, or sporking a shred or what when we get the signal to start learning. I can see running a concurrent shred that is always listening and "learning" but only updates the mapping table when MACHINE_IS_LEARNING == true, but that wouldn't be terribly efficient.
I'm assuming that I need to loop something like this inside the function call:
Code:
while ( podxtinport.recv(msg) ) {
      // get messages and update local variables
      // when the signal to exit learn mode is received, update table
Will I also need to chuck one of those MidiIn objects to now? Advancing time is still a hazy issues for me.
PostPosted: Fri May 18, 2007 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you should feel right at home. ChucK is actually meant as a teaching tool for novice programers so welcome!
And yes; chucking a midi input to now mean "this shred now has to wait for MIDI input before doing anything" (likely it'll be parsing that input).
If I understand what you are trying to do corectly then yes; a lookup array would be a good solution. When the program is in "learn" mode it could extract the channel and cc# from one message, map that to a apropriate channel and cc that it'd get from the next messsage and from there on it would use that data to turn one into the other.
You could use a 16 by 128 array for this, representing 16 MIDI channels with each 128 CC's. Likely you can get away with that and a extra field to hold the Pod's MIDI channel because I imagine something like a Pod only uses one channel?
clembie
PostPosted: Fri May 25, 2007 6:32 pm    Post subject: listen to 2 MIDI inputs at once Reply with quote  Mark this post and the followings unread
Thanks, Kassen! I'm making progress...
How do I make chuck listen to two different MIDI inputs at once?
I have to poll them both, don't I? I can't chuck them both to now, right?
clembie
PostPosted: Sat May 26, 2007 6:56 am    Post subject: PODxt MIDI driver, version 1.0 Reply with quote  Mark this post and the followings unread
Okay, this miserable hack (attached) is the first version of the midi router for my PODxt. It does implement a poor-man's midi-learn functionality which can be triggered by using a particular key on the midi controller.
I used a small lookup table (instead of a 16x128 table) because the midi channel is controlled on the devices and I didn't want to mess around with managing something of that size.
My only regret is that there's no data persistence. I really wish that I could hook chuck up to a mysql database or something similar. Can you imagine the data-sonification possibilities?! Smile
clm
pod-driver.ck
FYI, if debug is set to 1, this will print all kinds of extra strings to the console.
 Filename:  pod-driver.ck
 Filesize:  6.08 KB
 Downloaded:  221 Time(s)
PostPosted: Sat May 26, 2007 9:43 am    Post subject: Re: listen to 2 MIDI inputs at once Reply with quote  Mark this post and the followings unread
That's right, you can't (currently) make one shred wait for two ports. You don't need to either, if I understand it all corectly the two ports will ahve very different relationships to your program with different functionality behind both so that's not so bad. Do remember to give the ports and the mesages nice and sensible names or you'll get confused (ok, I messed that up myself in the past and *I* got confused...)
I had a quick glance at your code and it all looks very clean and structured to me. I'd say you are on the right track. Personally I feel that there is no better way of learning then starting out with a simple but usefull project.
