G2 as a digital control device
Page 1 of 1 [5 Posts]
TheRain
G2 patch files: 9
PostPosted: Wed Apr 12, 2006 10:35 pm    Post subject: G2 as a digital control device
Subject description: g2 more than music?
It occured to me at one point that things like the logic modules and stuff might be useful for connecting to my electronic experiments... electronic as in non-musical experiments.. as in electronic devices I'm building. The first test I did was to hook up my digital multi meter to one of the audio outputs of the G2 and in the G2 editor I hooked up a "constant" module. I thought that this might be capable of placing a constant voltage on the output. The output meter in the editor increases and decreases accordingly when you change the constant... but when I tested it with the multimeter at the output, the voltage appeard to always come to rest at around 2 MV (or something like that, can't remember specific.). It did seem to change when I was moving the knob, but once I stopped it seemed to come to rest at the same value every time. So I decided to try reading an OSC at the output and amplify and deamplify it and see what the A/C voltage was. This resulted in variations from 0 to 300 MV. I understand that normal line voltage is supposed to be somewhere around 1V max so i guess it falls in that range.
Anyway, that's just a little report on my dallying today. Anyone else here mess with electronics and are interested in this sort of thing with the G2? Anyone have some thoughts on it? I was thinking that maybe I could use a capacitor and level out the rise and fall of oscilation and boost or cut the voltage as desired to interface with some of my microcontrollers and IC's and stuff.
Fozzie
G2 patch files: 49
PostPosted: Thu Apr 13, 2006 12:19 am    Post subject: Re: G2 as a digital control device
Outputs are AC coupled and thereby incapable of outputting DC currents (that's why after a while your multimeter keeps returning to one value).
TheRain
G2 patch files: 9
PostPosted: Thu Apr 13, 2006 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Fozzie, thanks... that's a term I had not heard before. I figured it must be something like that though. Any other thoughts?
PostPosted: Thu Apr 13, 2006 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
If you do some microcontroller experiments, try to make a MIDI interface for them. Then the G2 could talk to the uC via MIDI, sending 7bit values. Use the uC as a DAC, or ADC, while the G2 does all the brain work helping you develop your algorithms.
TheRain
G2 patch files: 9
PostPosted: Fri Apr 14, 2006 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, that's a good idea. I have done MIDI output with PIC before, but never input...
