Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Fri Feb 06, 2004 12:25 pm Post subject:
RSS feeds now available from electro-music.com |
As a free service to other web sites and individuals with above average technical skills, RSS (Really Simple Syndication) feeds of electro-music.com's online forum are now available. We provide several URLs to get these feeds:
rss.php - provides up to 50 of the most recent topics from all of our publicly readable forums. The format of this feed is XML in the RSS standard. Your web site will need to format these feeds in an appropriate style. There are a couple of http arguments you can use to control the feeds:
c=20 would limit the feed to only 20 topics. The max is 50.
t=1 returns posts. The default is t=0 which returns topics, probably the most useful.
For example to return the last 10 posts, use http://electro-music.com/forum/rss.php?c=10&t=1
rss.php returns the text of the topics. In case you don't want the entire text, we provide another program, rss2.php, for just the headers. Yet another program rss3.php provides a feed of just the News the electro-music.com forums. The t and c options work with these URLs as well.
If you have any questions, or to request variations on these feeds, please post them as replies to this topic.
----- EDIT September 4, 2004 ----
I just modified rss.php and rss2.php to take multiple forum number for the f= argument. For example, to get the feed of just the "Misc News" (35) and the "Wish List" from the Nord Modular forum (77) use this url: http://electro-music.com/forum/rss.php?f=77,35
Also, added rss4.php to give a feed of all of the Nord Modular topics...
----- EDIT September 6, 2007 ----
The t option has been deactivated. It's now set permanently to t=1
----- EDIT September 10, 2007 ----
This program has been upgraded this topic is obsolete. See http://electro-music.com/forum/topic-20444.html Last edited by mosc on Wed Sep 19, 2007 10:34 am; edited 6 times in total |
Posted: Fri Feb 06, 2004 2:30 pm Post subject:
OK.. now we have to ask Jeff Harington to test this one too? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 107
Posted: Fri Feb 06, 2004 2:54 pm Post subject:
| elektro80 wrote: | | ask Jeff Harington to test this one too? |
I just PM'd him.
If it wasn't for you, I'd have never known about RSS. |
Posted: Fri Feb 06, 2004 2:57 pm Post subject:
I always cause more work.. I am a mess.
One the other hand.... _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
jeff harrington
Posted: Sat Feb 07, 2004 10:06 am Post subject:
It worked fine for me. You did not copy the html, did you?
You can see the rss3.php running at my site. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
jeff harrington
Posted: Sat Feb 07, 2004 10:51 am Post subject:
I'm running it through a very very anal validator that's all...
http://feedvalidator.org
Always validate!
For safety sake!
 _________________ music
portal
blog |
Posted: Sat Feb 07, 2004 11:06 am Post subject:
The "Swedish Anal Validator"?
Flickr |
Audio files: 107
Posted: Sat Feb 07, 2004 9:53 pm Post subject:
| jeff harrington wrote: | It didn't validate because of the character encoding used?  |
Apparently, that's because of this:
| Quote: | Message
UnicodeError: decoding error, invalid data
Explanation
Your feed contains an invalid character.
Solution
A common cause of this error is having a high-bit character (such as a curly quote or curly apostrophe) in your RSS feed. This can happen if you copy-and-paste a quote from another page that contains curly quotes. For maximum compatibility with readers, you should remove the invalid character or use a numeric entity equivalent.
You can also try changing your character encoding to a more liberal encoding. For example, if you have this at the top of your feed:
<?xml version="1.0" encoding="utf-8"?>
Try changing it to this:
<?xml version="1.0" encoding="iso-8859-1"?>
This can be a difficult error to diagnose, because the validator can not give you the exact location of the error. (This is due to a limitation of our parsing library; sorry, we tried very hard to work around it!) For example, if the validator says the error occurred at the end of a description element, the actual invalid character could be anywhere within the description.
Not clear? Disagree?
Let us know on the feeds-archive-talk discussion list! |
I have it set to iso-8859-1. I changed it to utf-8 and got a similar but different error. This seems to be much ado about nothing. |
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Sun Feb 08, 2004 8:59 am Post subject:
guys, I am sorry to say that the content of this topic sounds Norwegian to me, even translating it with my Sondheimizer does not help
RSS is a Web content syndication format.
Its name is an acronym for Really Simple Syndication (it is discomforting to not understand something "really simple": it makes me sick ) _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
Audio files: 107
Posted: Sun Feb 08, 2004 9:06 am Post subject:
| Go to http://elektro80.trash.no/forums.html and look at the lower right of the page. The RSS feed give him this information, in XML format. It's just a mechanism to provide the feed of what's the latest topics in the forum. Don't worry about it. |
seraph
Editor
Audio files: 31
Posted: Sun Feb 08, 2004 9:30 am Post subject:
now I see thanks Howard
that's way cool
Stein does the same with www.osxaudio.com, mstation.org etc.
and btw RSS stands for Rich Site Summary
(I already feel better ) _________________ homepage - blog - forum - youtube
Audio files: 107
Posted: Sun Feb 08, 2004 9:55 am Post subject:
| seraph wrote: | and btw RSS stands for Rich Site Summary
(I already feel better ) |
So it does.
Don't know why. It's not rich.  |
Threetwosevensixseven
Posted: Sat Sep 04, 2004 6:15 am Post subject:
Awesome!
I just discovered the delights of RSS for the first time today. I'm a big fan of newsgroups, mailing lists and forums, but have often wished I could get forum content pushed to me like emails so I could have the best of both worlds.
Using my regular email client Mozilla Thunderbird, with the ForumZilla extension, it is dead easy to set up an RSS feed to pull forum topics into folders, such that each topic appears much like an html email message.
It's worth mentioning that Howard's magic can feed a single subforum too. example:
http://electro-music.com/forum/rss.php?f=63
will get the Nord Modular Discussion subforum only. So you could set up multiple single-forum feeds into different folders, if you wished.
Now I'm happy
Cheers, 3 |
Audio files: 107
Posted: Sat Sep 04, 2004 9:16 am Post subject:
| Wow, great information. I haven't switched to Thunderbird. I still use the Mozilla all-in-one package. Would you say it is robust enough? Is it ready for prime time? Do you think I should jump in and make the switch? What's the scoop? |
Audio files: 107
Posted: Sat Sep 04, 2004 9:23 am Post subject:
| Holy tamolli! You can run the Forumzilla in regular Mozilla mail. You don't need Thunderbird. Fab. |
Forget those naked women... RSS is hot!  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sat Sep 04, 2004 9:49 am Post subject:
| mosc wrote: | | I haven't switched to Thunderbird. I still use the Mozilla all-in-one package. Would you say it is robust enough? Is it ready for prime time? Do you think I should jump in and make the switch? What's the scoop? |
Not really the right person to ask, as I've only been using Firefox/Firebird for about 6 months and Thunderbird for about a month. I figured they had to be better than Scrimfoot products, and they are. But I'm not sure about robust. Firefox has managed to lose my un-backed-up bookmarks twice, and I've managed to break my Thunderbird folder structure in an interesting way. But I'm sticking with 'em.
You beat me to it, Mozilla Mail has a version of Forumzilla. There's one for Outlook called NewsGator too, it seems.
I just took a look at a sample mysql>rss php generator. Frighteningly simple yet effective stuff
Cheers, 3 |
Audio files: 107
Posted: Sat Sep 04, 2004 1:26 pm Post subject:
See the edit I made to the first post of this forum. I enhanced both rss.php and rss2.php so that the "f" argument can take a list of forum numbers. So, to get all of the NM forums, for example, use:
http://electro-music.com/forum/rss.php?f=43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,77 |
Audio files: 107
Posted: Sat Sep 04, 2004 1:36 pm Post subject:
| Well, I just added rss4.php to give just the Nord Modular topics - for convenience... |
Posted: Sat Sep 04, 2004 1:52 pm Post subject:
Posted: Sat Sep 04, 2004 4:36 pm Post subject:
Wowzers! Cool!  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
aquanaut
Posted: Sun Sep 05, 2004 12:58 am Post subject:
| That's interesting. Is it possible to have the feed with an older mozilla app (1.21 the new software is for os x. |
