Question about Roland CSQ 100
Page 1 of 1 [14 Posts]
Wild Zebra
PostPosted: Thu Oct 11, 2007 9:06 am    Post subject: Question about Roland CSQ 100 Reply with quote  Mark this post and the followings unread
Hello, I bought one of these a while ago without realizing they do not work with Arp or Yamaha synths. Does anyone know why or of a simple circuit I could make to interface it with my Yamaha. Seems to be only compatable with Roland and Oberheim and I've read Prophet.
"your stripes are killer bro"
deknow
PostPosted: Thu Oct 11, 2007 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
...it should work with the arp, but the yamaha (cs series?) is probably v/hz, and not compatible.
i'd check the manual:
http://www.synthesized-dreams.com/download/manuals/CSQ-100Manual.zip
deknow
Wild Zebra
PostPosted: Thu Oct 11, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it's a CS 5, so thats HZ/V so I could use it with my Korg X-911 guitar synth huh? I have a music from outer space sequencer and I can control the yamaha with it. Confused
deknow
PostPosted: Thu Oct 11, 2007 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
the cs5 is a very nice sounding (and underrated) synth, imho.
the csq was supposed to work with the sh 101, which is v/oct and vtrig. most arps are the same as far as i know. if for some reason it takes an strig, you can find other threads that cover making a converter.
deknow
deknow
PostPosted: Thu Oct 11, 2007 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
...also, the paia fatman is a reasonable midi/cv converter for the yamaha (and can feed the external input)...and a synth to boot!
deknow
Wild Zebra
PostPosted: Thu Oct 11, 2007 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes the yamaha does sound very nice. In the manual it doesn't say anything about hz/v. Hell I don't know maybe it's broke.
PostPosted: Thu Oct 11, 2007 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
The CSQ simply doesn´t do hz/v.
Flickr
Wild Zebra
PostPosted: Thu Oct 11, 2007 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
So do you reckon it is just a marketing thing when they say it is only compatible with Roland and Oberheim gear? I just can't get it to work with the CS-5. I can't get it calibrated Electro 80. When I hit the cali button the note "wavers" (vibrato like sound) and never actually calibrates.
deknow
PostPosted: Thu Oct 11, 2007 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
read my other posts again...it will NOT work with the cs-5. if i remember correctly, the cs5 does use a vtrig (i might be mistaken), and you could fire the envelopes and extermal input with it, but the cv won't scale the oscillators or filter correctly.
the csq _should_ work with your arp, assuming your arp has cv/gate ins.
deknow
ldt
PostPosted: Fri Oct 19, 2007 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
As said: The CS series is Hz/V and all Roland stuff is Oct/V, so it won´t work.
There is one piece of hardware that was made to bridge the gap between Korg/Yamaha and most-other-synths. It is the Korg MS-02, but they are rare.
Nosferatu
PostPosted: Fri Oct 19, 2007 12:07 pm    Post subject: Re: Question about Roland CSQ 100 Reply with quote  Mark this post and the followings unread
Take a ordinary expo, then add a inverting Op amp on the current out pin
of the NPN based expo, what you get are are a Oct Volt to Hz/Volt converter.
Now you can drive your CS5 with the CSQ100.
Nosferatu
PostPosted: Tue Oct 23, 2007 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the fine and excellent info! Rolling Eyes
Audio files: 116
G2 patch files: 317
PostPosted: Tue Oct 23, 2007 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nosferatu wrote:
Thnak you for the fine and exellent info! Rolling Eyes
Maybe it was a bit too compact for the average reader Confused Laughing
Nosferatu
PostPosted: Tue Oct 23, 2007 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it was a bit too compact for the average reader Confused :lol
To compact?? You meant to advanced? Smile
Niio1
