  bingsatellites Mostly Ambient
NordLead Percussion mode
Page 1 of 1 [4 Posts]
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Sep 29, 2007 8:23 am    Post subject: NordLead Percussion mode Reply with quote  Mark this post and the followings unread
In these two mp3's the same sequencer input was used to two NordLead2 Slots, only different Banks (home made, of course)
Wout
DrumSequenceNL2-05.mp3
Sound
 Filename:  DrumSequenceNL2-05.mp3
 Filesize:  265.02 KB
 Downloaded:  274 Time(s)
DrumSequenceNL2-1P0-02.mp3
Sound
 Filename:  DrumSequenceNL2-1P0-02.mp3
 Filesize:  246.04 KB
 Downloaded:  286 Time(s)
Luko79
PostPosted: Wed Oct 03, 2007 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey woot Smile
i have been getting into using the nord rack 2 and its 4 banks as a simple drum machine or drum tone module, with kick on bank A and snare on Bank B and maybe 2 different hat settings on Banks C&D
however i have noticed you can only edit the overall sound of the perc kit, not each indicviual sound in the kit, hence why i assign one sound to a bank, that way i CAN edit the sound of the kit, and it only really affects the sound within the kit i want it to
i have been getting into also sampling some nice clean 808 booms and other 1 shots out of it tho for use in my own software sampler
has been fun - and successful!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 03, 2007 10:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is rather strange! In my NordLead2, not an 'X', I can change all 8 sounds in each Slot, so using 4 Slots I'm able to create 32 different drum sounds or effects. The only limitation is the number of Voices (can't use them all in one 'boom'). I can't save these changes in the synth, only on a PCMIA card or on the hard disk using Midi Sysex.
I advise you to read the Manual again! [Page 29 and further] Beware the LFO settings are global to a individual bank.
Wout
Luko79
PostPosted: Wed Oct 03, 2007 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have a lead 2 not an 'x' and i havent figured out how to adjust say the snare in one kit and not the kick drum, if you tweak the kit all sounds within the kit are changed too
yes i can always still get each sound out of the kit via playing different keys on my midi keyboard but its the tweaking the snare to be thinner say aand the kick in that same kit to be fatter or fuller
I must have missed something in the manual, if i could get it working how you use it I would be very happy indeed Smile
will be digging the manual out when i get home, but i have read it a few times....must have missed it
cheers!
Niio1
