Unit tests for ChucK
heuermh
PostPosted: Thu Nov 29, 2007 10:53 am    Post subject: Unit tests for ChucK Reply with quote  Mark this post and the followings unread
Here is something like an unit test framework for ChucK programs.
The pattern for an unit test looks like:
Code:
class MyUnitTest extends Assert
    // set to true to exit immediately on test failures
    true => exitOnFailure;
    // call test methods explicitly
    testFoo();
  public void testFoo()
    assertTrue(...);
// run unit test
MyUnitTest unitTest;
<<<"ok">>>;
See e.g. http://junit.org for more on what you can do with unit tests.
michael
unit_test.ck
Unit test framework for ChucK programs plus an unit test for the unit test framework.
 Filename:  unit_test.ck
 Filesize:  9.35 KB
 Downloaded:  22 Time(s)
Top Selling Products! CLICK HERE!
