numbernone
Joined: Aug 16, 2006 Posts: 476 Location: new york city
Posted: Mon Sep 17, 2007 9:47 am Post subject:
Big FAT sliders for the Klee?? |
I had initailly fantasized about slide pots for the Klee, but abandoned hope as I practically never see sliders in DIY projects. How glad I am to see so many slide Klees!! Anyhow, mostly I am coming up short of finding anything but 60mm pots. Can anyone comment on the precision you can attain with 60mm? Ideally I would like to find 100mm, but pretty much everything I can locate are audio taper, or the wrong value.
Better yet, who the heck makes a BIG FAT slide pot, as found on the Technics turntables. How nice it would be to have those sweet long throw babies with stiff resistance. Any clues?
This could easily balloon into a Rolls Royce type project, but who cares?? Sequencers are always expensive, and pretty much never as cool as the Klee has shown itself to be.
Big ups to the whole test crew, keep the sick samples coming. |
loopcycle
Posted: Sun Nov 25, 2007 4:15 pm Post subject:
i couldnt find 100mm sliders in linear, so i ordered 60mm.
considering the range functionality, i dont think a shorter slider will be detrimental to the design IMO.
did anyone using sliders use any *smaller* than 60mm? |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Sun Nov 25, 2007 4:19 pm Post subject:
Mine only have a travel of 45mm and they work great. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Rykhaard
Posted: Sun Nov 25, 2007 8:28 pm Post subject:
| Uncle Krunkus wrote: | | Mine only have a travel of 45mm and they work great. |
Hey Unc. Where'd you get yours from, and how much? I haven't yet settled on using pots and am starting to think I may prefer sliders as well. (Hoping Mousers, as I'm placing a switches order at the end of this coming week. ) |
Audio files: 51
Posted: Sun Nov 25, 2007 11:04 pm Post subject:
Believe it or not, I found them in Dick Smith's online catalogue. (I don't think I've seen them in stock for years, must be just sitting in the warehouse gathering dust) They only have one flavour too! 50K linear 45mm travel. I thought, yep, that's just what I'd like. Roughly AU$1.80 each.
They do have a centre detent. Which you might like or not. (It's possible, although tedious, to remove it. I didn't.) And I would certainly advise you to order 20-25 so you can chuck the "weird" ones, but I reckon they're great value. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Audio files: 51
Posted: Mon Nov 26, 2007 1:16 am Post subject:
I'll just clarify that.
By "weird" ones, I don't mean the ones which are way off 50K total resistance. If you leave the centre detent operational, you want the ones which read closest to half the total resistance when they're in the detent. The ones that deviate the most from "half the total resistance at the detent" should be put aside.
This is mostly so that if you dial up a Max Voltage of say, 2V(oct) then the detent position will be closer to 1V(oct). Does that make sense? _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Posted: Mon Nov 26, 2007 3:07 am Post subject:
i will use 30mm sliders. though the klee is not finished yet, i hope it will work fine.
IIRC scott even thought about replacing the sliders with switches! a lot of work is done using the scaler, i think. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Audio files: 51
Posted: Mon Nov 26, 2007 3:17 am Post subject:
Yes, you can do great stuff with sliders just in their full up and full down positions. Especially if you choose your voltage scales carefully and have them properly tuned. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Rykhaard
Posted: Tue Nov 27, 2007 7:45 am Post subject:
| Uncle Krunkus wrote: | | Yes, you can do great stuff with sliders just in their full up and full down positions. Especially if you choose your voltage scales carefully and have them properly tuned. |
Thanks for the mention of where to get them Unc! 16 x $1.80 Aus. isn't too bad, either.
| fonik wrote: |
30mm ...... just over an inch. It'd still work. It's just a little tighter at 2V or higher, in finding the proper divisions.
I myself would like 60 to 100mm, ultimately.
The mention of switches though ...... 4 or 6 position rotary switches would be nice.
Ultimately, once again - 12 position with a constant current source for 1V/oct., is my biggest desire. With a +/-1 octave switch per step as well. I'll be investigating that mod. possibility, if there's another run of boards, as I'll be picking up a 2nd one for sure.  |
krisp14u
