 Forum index » Instruments and Equipment » MAX/MSP - Pd
Max/Msp Synth - please help
Page 1 of 1 [4 Posts]
c00p
PostPosted: Fri Apr 04, 2008 8:04 am    Post subject: Max/Msp Synth - please help Reply with quote  Mark this post and the followings unread
Hey everyone! I'm pretty new with this stuff, and I'm trying to make a synth where the upper half of my MIDI keyboard plays a sine synth that goes through an effect, and I want the bottom half of the keyboard to control the parameters of the effect... Can anybody help me?
cbm
PostPosted: Fri Apr 04, 2008 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
What do you have so far? It's not too difficult a problem. Where are you stuck?
I have several Max examples that you may find helpful up at http://www.xfade.com/max/examples
-C
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
c00p
PostPosted: Fri Apr 04, 2008 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I have made a simple sine synth so far... I guess the effect is added just by adding it to the synth signal flow (?), but I don't know how to assign the effect to the keys, as described in my first post.
cbm
PostPosted: Fri Apr 04, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, you would add the effect on the output of your simple synth. If you used poly~ to implement your synth, it would go between the output of poly~ and the dac.
To separate the lower octave, you could use an object like split on the stream of numbers from notein. Or a switch controlled by a < on the note stream, which routed the notes below some threshold one place, and the ones above the threshold to your synth.
There are many ways to do just about anything in Max.
This Max list is pretty quiet. The Cycling '74 Max list is much more active.
Chris Muir
