DIY electronic drum pads
Page 1 of 1 [7 Posts]
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sun Jan 30, 2005 10:19 pm    Post subject: DIY electronic drum pads Reply with quote  Mark this post and the followings unread
I'm thinking about building a couple of electronic drum pads....I'm looking to make these things sturdy (obviously they are going to be hit a lot) but as inexpensively as possible. Has anybody had experience building these things they would care to share, or know of a good, inexpensive manufacturer of peizo transducers?
DrJustice
PostPosted: Mon Jan 31, 2005 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
A few years back I made a heap of drum pads using Remo practice pads and piezo transducers. Don't know the make of the piezos, but they were the 'standard' type, maybe 4 cm in diameter. The piezos were placed under the skin, on top of the foam insert inside the pads. It worked quite well. On top of the skin, right above the piezos, small rubber foam pads were placed to protect the piezos from direct hits. The next pad project will be baed on neoprene mats, since they make a lot less acoustic noise when hit.
Of course one would need a trigger unit. I use an Alesis D4, highly recommended for the purpose. A friend of mine used a Roland Octapad for his pads.
DJ
dnny
PostPosted: Fri Oct 14, 2005 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
take a look at this
www.koelse.org
flickr: cable porn group
algorhythm
PostPosted: Fri Dec 16, 2005 11:37 am    Post subject: Re: DIY electronic drum pads Reply with quote  Mark this post and the followings unread
zynthetix wrote:
...inexpensive manufacturer of peizo transducers?
Experimental Musical Instruments sells peizo pickups and a book, Getting a Bigger Sound, on how to use them.[/u]
Macaba
PostPosted: Sun Jan 01, 2006 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Referring:
http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/drum_trigger.html
mikejl47
PostPosted: Mon Jan 07, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
diy electronic drums http://www.edrums.info
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jan 07, 2008 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good !
welcome
Niio1
