Developing ChucK
Page 1 of 1 [4 Posts]
Frostburn
PostPosted: Wed Jan 30, 2008 3:15 am    Post subject: Developing ChucK Reply with quote  Mark this post and the followings unread
I need some speed for my anti-aliased oscillators and waveshapers so I'm thinking of tackling my C++ illiteracy and extending ChucK.
I'll also try to fix how oscillator phase is handled at the moment (phases out of [0.0, 1.0] range don't work as expected, ie. warp back to said range. Should also fix FM modulation with negative frequencies)
Who should I contact, if anyone at the moment?
Where do I post the fixes when they're done?
Anything I should know before starting to work with the source?
To boldly go where no man has bothered to go before.
PostPosted: Wed Jan 30, 2008 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
I'd start with the improvements, then move on to including new Ugens in the source. If you have some results that work I suppose the thing to do is send it to the -dev list or Ge personally.
If you would get stuck I suppose the -dev list would be the place to go but I don't think that list is aimed as DSP in C++ tutorials or C syntax, it's probably the perfect place for questions on how the insides of ChucK actually work though,
I have no idea what the conditions for access to the versioning system thingy is, probably speaking C++ is a part of those :¬) I think the main thing is getting your code to work, partially because that's what you want in the first place.
I suppose you could mail Ge about what you want to implement and how to make sure there's a demand for such oscillators to avoid disappointments?
Oh, and if you do succeed in getting a new Ugen to work, could you document the steps you took? I'd be quite interested in that.
while(!machine.crash() ) <<<"all is well">>>;
renderful
PostPosted: Sun Feb 03, 2008 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd love to hear about your progress, as I am also thinking of extending Chuck in a few ways. The C++ Ugen sources for the STK are amazingly helpful. Keep us updated!
Frostburn
PostPosted: Mon Feb 04, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a lot of stuff in the source that one propably should know about before creating anything new. And I am totally new to C++ so there haven't been much progress. I think I've fixed the Phasor UGen though.
I'll try to implement anti-aliasing for all the basic oscillators and post the modified ugen_osc.cpp here. (unless posting single files from a source goes against GPL or something. (?) )
EDIT: I just did that. (see attachment)
It is a modified version of the ugen_osc.cpp from the latest Linux source of ChucK. Just replace the one you have and type make. No warranties! I cannot be held responsible if it blows up your machine. :)
Features:
-Phasor should work properly with all sync modes.
-SinOsc TriOsc and PulseOsc now have automatic anti-aliasing applied to them. (SawOsc is a TriOsc with width fixed to 0.0 or 1.0 so it's dealt with automatically) As a side effect of the new implementation this should also fix sync modes.
I still haven't made an oscillator from scratch. Just modded the old ones.
EDIT2: Um... I think I just divided by positive zero or something in an oscillator... Back to the drawing board. That is to say the code I posted is buggy.
ugen_osc.cpp
modified ugen_osc.cpp from the source of chuck version: 1.2.1.1 (dracula).
 Filename:  ugen_osc.cpp
 Filesize:  53.59 KB
 Downloaded:  14 Time(s)
Top Selling Products! CLICK HERE!
