On using one logic family
Page 1 of 1 [10 Posts]
Audio files: 107
PostPosted: Mon Feb 11, 2008 11:13 am    Post subject: On using one logic family
Subject description: Thinking out loud - general principles
Before starting a Lunetta, it's a good idea to consider standardizing on using on logic family. We can discuss this ad nausium, but let me state a few points as general principles based only on experience.
CMOS is the logical choice because:
CMOS is very forgiving to power supply ranges. Usually, you can use virtually any DC voltage source you have.
CMOS is low-power by nature. CMOS only uses power when the logic changes from one state to another. Since our circuits will ususally clock at low frequencies (audio is very low frequency compared to usual logic rates).
TTL and others draw power constantly, so not a good choice.
The CMOS 4000 series is a good choice for standardizing because parts are cheap and readily available. 4000 logic can almost always work interchangeably with the 74C000 series, just in case. 4000 can also drive TTL in some cases as well.
So, based on the suggestion by Bugbrand himself, I think 4000 is a good logic family to start with here.
Comments welcome...
Audio files: 116
G2 patch files: 317
PostPosted: Mon Feb 11, 2008 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
And one CMOS output can drive many CMOS inputs (even when some conditioning input resistors are present), whereas for TTL an output drives around 10 inputs or something.
bugbrand
PostPosted: Mon Feb 11, 2008 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
And they come in many tasty flavours too!
http://en.wikipedia.org/wiki/List_of_4000_series_integrated_circuits
I've never really had the chance/need to look so much at TTL chips..
http://www.bugbrand.co.uk
widdly
PostPosted: Wed Feb 13, 2008 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This page has a good information on the 4000 series...
http://www.kpsec.freeuk.com/components/cmos.htm
It doesn't cover some of the more obscure ones though.
Audio files: 107
PostPosted: Thu Feb 14, 2008 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
TTL is really not as good for CMOS in these applications. I think 4000 series is the way to go, but if there are better choices, we're all ears.
Audio files: 51
PostPosted: Fri Feb 15, 2008 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm all for 4000 series.
With a 100nF across the power supply pins, 100K to ground on all inputs, and a 2N3904 buffered LED on every output, are all chances of static problems quenched?
We would lose our friends.
So,.........
Audio files: 107
PostPosted: Fri Feb 15, 2008 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
No all chances of static damage, but lets try it out and see what happens.
I would prefer to tie inputs up to Vcc with a resistor, instead of ground. The reason is that if you touch the input thru a patch cable to the grounded front panel, you get a way to "play" the circuits directly "by hand". But either way is OK.
CJ Miller
PostPosted: Tue Mar 11, 2008 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Emitter-Coupled Logic is the wave of the future!
;]P
Audio files: 107
PostPosted: Wed Mar 12, 2008 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
;]P
I know a guy that has over 100 patents for ECL. He was a world authority on the subject. He ended up designing CMOS microprocessors... Smile
CJ Miller
PostPosted: Fri Mar 14, 2008 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's amazing! I was only half joking about ECL being The Next Big Thing because of how the industry largely ignored it, but I bet an ECL Lunetta would be quite distinctive! I don't think I am ready for that challenge yet myself.
Alas... Well, I've got no credentials whatsoever, so as a result nobody has ever hired me to do anything even remotely interesting. But I won't let it stop me from trying.
