  Faux Pas Quartet and friends Music From Last Thursday
Stormtide-Flanger LFO - some questions
Page 1 of 1 [5 Posts]
Boerge
PostPosted: Wed Nov 20, 2013 2:54 am    Post subject: Stormtide-Flanger LFO - some questions Reply with quote  Mark this post and the followings unread
Hi all,
I'm trying to figure out how this LFO works:
http://www.jhaible.com/jh_storm_tide_1.pdf
Th LF412-part is clear, an integrator and a trigger in a loop. But then comes the CA3080: if the switch (Ramp/Dive) is closed, the outputs of both ICs are connected together. Ok, should work as long as the outputs are not overloaded (btw: would this also work with a TL082 or would that kill it?).
So I made some sims with LTSpice, exspecially for necessary changes when I use a LM13700 instead.
If the switch is open everything works as expected:
http://boergeweb.de.vu/files/Sim_sw_open.png
The output Out1 has a triangle curve, the output of the LM13700 doesn't mind in that case.
But when I close the switch (ok, the connection in the schematic Wink ) the output Out2 shows the same triangle:
http://boergeweb.de.vu/files/Sim_sw_closed.png
Where is the unsymmetric sine? Can such a thing (connected outputs of 2 OpAmps) not be simulated?
My third try was to sum the outputs with another Opamp, that works as expected:
http://boergeweb.de.vu/files/Sim_opamp_sum.png
Should I put a resistor between the outputs or would it work as in Juergen's original schematic?
headscratching greetings
Boerge
...ich will doch nur löten...
Designator
PostPosted: Wed Nov 20, 2013 8:02 am    Post subject: Re: Stormtide-Flanger LFO - some questions Reply with quote  Mark this post and the followings unread
For your simulation you should add the 50k pot, the CA3080 then outputs a kind of bended triangular wave.
Regards
Boerge
PostPosted: Thu Nov 21, 2013 4:56 am    Post subject: Re: Stormtide-Flanger LFO - some questions Reply with quote  Mark this post and the followings unread
Hmm... not in the sim:
http://boergeweb.de.vu/files/Sim_sw_closed_with_pot.png
In LTSpice it is the same triangle wave, not the (expected) U-shaped...
(I added a 50kOhm resistor instead a pot, but for the OTA output it's the same thing.)
But: last evening I did some soldering, and like I assumed in my last post a resistor between the LM13700- and the TL082-output did the trick. I think I will try today the pot instead my resistor and decide, which is better and what resistor value works best.
regards
Boerge
Designator
PostPosted: Thu Nov 21, 2013 7:12 am    Post subject: Re: Stormtide-Flanger LFO - some questions Reply with quote  Mark this post and the followings unread
Hi Boerge,
well, the virtual 'switch' is in 'Ramp' - mode, so to say, you have to delete the connection between 'out1' and 'out2' to see the effect of the OTA. To use a resistor is ok here, it forms a voltage divider together with the 620k resistor.
My guess on this LFO is, that there is a triangle wave -'Ramp', and a second wave, which is a compressed triangle, not complete sine like. The
switch just acts as a bypass. However, the labelling 'Dive' raises expectations about something more spectacular, perhaps.
IIRC there is an LFO with an OTA, that generates an asymmetrical U-shaped wave, that of the EH SmallStone phaser. There the OTA is part of the
integrator-comparator-loop, whereas here the OTA serves as a distortion/waveshaping device.
Boerge
PostPosted: Thu Nov 21, 2013 7:58 am    Post subject: Re: Stormtide-Flanger LFO - some questions Reply with quote  Mark this post and the followings unread
Hm... you mean ramp mode when the switch is closed? So there would be an error in Juergens drawing, the switch should change between the outputs of the OTA and the LF412?
Right, I tried it in my sim, and it works as expected...
Yes, the second wave is rather U-shaped,
Designator wrote:
The switch just acts as a bypass.
It's just somekind of "brute force" IMHO Wink because it connects the outputs directly. It would be better to toggle between Out1 and Out2. But now I understand Juergens comment (on http://www.jhaible.com/jh_storm_tide_flanger.html):
"The Switch performs a brute-force override from the triangle LFO when its closed"
Not really Wink What the sim shows is quite that what I did expect, an U-shaped wave, similar to a full rectified AC wave (the negative half).
Ok, I will see it in the evening Smile
Thanks for your replies
regards
Boerge, wintertime is soldering time...
