 Forum index » Artists » Static Strobe Emitter
8-Bit NES Chipmusic
Post new topic   Reply to topic Moderators: Static Strobe Emitter
Page 1 of 1 [9 Posts]
Audio files: 96
PostPosted: Mon Mar 03, 2008 7:29 am    Post subject:  8-Bit NES Chipmusic
Subject description: Let the chips be with you!
This was a pretty popular console back in the 1980s.
For those unfamiliar with what it is can go into this wikipedia link
http://en.wikipedia.org/wiki/Nintendo_Entertainment_System
The soundchip specs are (directly from wikipedia):
The NES board supported a total of five sound channels. These included two pulse wave channels of variable duty cycle (12.5%, 25%, 50%, and 75%), with a volume control of sixteen levels, and hardware pitch bending supporting frequencies ranging from 54 Hz to 28 kHz. Additional channels included one fixed-volume triangle wave channel supporting frequencies from 27 Hz to 56 kHz, one sixteen-volume level white noise channel supporting two modes (by adjusting inputs on a linear feedback shift register) at sixteen preprogrammed frequencies, and one delta pulse-width modulation channel with six bits of range, using 1-bit delta encoding at sixteen preprogrammed sample rates from 4.2 kHz to 33.5 kHz. This final channel was also capable of playing standard pulse-code modulation (PCM) sound by writing individual 7-bit values at timed intervals.
I will convert all tracks to MP3 for easiest playback.
However if i gets asked to give away a source to be compiled code for
replaying on a real NES hardware i can provide that for each individual track.
Cheers!
Audio files: 96
PostPosted: Mon Mar 03, 2008 7:37 am    Post subject: Mystery Roses of Affinity
Subject description: NES
hello =)
strobe-mysteryrosesofaffinity.mp3
blips'n blops!
 Filename:  strobe-mysteryrosesofaffinity.mp3
 Filesize:  4.76 MB
 Downloaded:  289 Time(s)
Audio files: 96
PostPosted: Mon Mar 03, 2008 7:43 am    Post subject: Tantalum Molly Reply with quote  Mark this post and the followings unread
waffles?
strobe-tantalummolly.mp3
more blips n' blops =o
 Filename:  strobe-tantalummolly.mp3
 Filesize:  5.35 MB
 Downloaded:  296 Time(s)
Audio files: 28
G2 patch files: 295
PostPosted: Mon Mar 03, 2008 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aah .. I had been missing that ... good to hear that the music still works Cool
Audio files: 96
PostPosted: Mon Mar 03, 2008 7:25 pm    Post subject: What orbits around my head? Reply with quote  Mark this post and the followings unread
=o
strobe-whatorbitsaroundmyhead.mp3
Seamless Dutycycle tricks, Massive DPCM abusing at the end.
Thanks to JSR for bankswitching capabilities!
 Filename:  strobe-whatorbitsaroundmyhead.mp3
 Filesize:  6.07 MB
 Downloaded:  341 Time(s)
Drone
PostPosted: Tue Mar 04, 2008 8:32 am    Post subject:   Reply with quote  Mark this post and the followings unread
Hey Static Strobe Emitter, nice to see you back & thanks for sharing !
It is at least ten times more difficult to get a good synthesizer sound than on an acoustic instrument. - Giorgio Moroder
G2 patch files: 17
PostPosted: Tue Mar 04, 2008 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, these are great! Glad to see you still in action!
myspace.com/triptechmusic
Triptech <-- new album!
Housefly
PostPosted: Sat Apr 12, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i had one of those, well actually it was a sega master system 8 bit. i still have a thumb (the right one) that is disformed from playing too much...
luckily strobe didn't compose the tunes back then... or the thumb would've dropped off completely
Audio files: 96
PostPosted: Tue Apr 15, 2008 6:34 pm    Post subject: =o.... Reply with quote  Mark this post and the followings unread
This is not NES, but it is 8-bit, so i better fit it in here Wink
This tune is an Atari tune, soundchip: Pokey
Composed in RMT (Raster Music Tracker).
Strobe - Robophobia III.sap.mp3
Robophobia III
brutal massacre of the poor pokeychip.
 Filename:  Strobe - Robophobia III.sap.mp3
 Filesize:  2.3 MB
 Downloaded:  283 Time(s)
Once You Know, You Newegg
