 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Nomad 0.3 pre-release available for DL
Page 1 of 2 [30 Posts]
chresan
PostPosted: Mon Mar 10, 2008 12:50 pm    Post subject: Nomad 0.3 pre-release available for DL Reply with quote  Mark this post and the followings unread
Code:
Nomad 0.3 pre-release announcement
Hi everyone,
the second release of Nomad - Nord Modular Editor is finally out.
After 1.5 years of developing since the first release we are happy
to announce that Nomad is almost feature complete.
Apart from the basic things we implemented some new features to
improve the experience with the editor:
- embedded file browser
- macros: create tiny template patches which can be inserted into other patches
- module transformation: transform a module into another without loosing parameter values and connections
- randomizer: randomize the parameters of a patch or a set of modules
- arbitrary number of Nord Modular/Micro Modular synthesizers supported
Requirements:
- Java Runtime Environment (JRE) 5.0
- platform: platform independent
OS X users might need to install a MIDI service provider (SPI). See
   http://nmedit.sourceforge.net/userpage/help.html#osx-midi
Starting Nomad:
OS X:
   start the nomad application file like any other application
other platforms:
   start nomad.jar like any other application
   or manually using the command
      java -jar nomad.jar
Downloads are available at
For support, questions, bug reports or anything else visit our forum at
   http://electro-music.com/forum/forum-138.html
http://nmedit.sf.net
chresan
PostPosted: Mon Mar 10, 2008 12:58 pm    Post subject: screens & screencast Reply with quote  Mark this post and the followings unread
Here are two screencasts from Manuel:
http://inflection.bl0rg.net/~manuel/nomad1.swf
http://inflection.bl0rg.net/~manuel/nomad2.swf
and below two screenshots of nomad.
nomad shot 1
 Filesize:  210.02 KB
 Viewed:  196 Time(s)
nomad shot 2
 Filesize:  273.12 KB
 Viewed:  155 Time(s)
JLS
G2 patch files: 274
PostPosted: Mon Mar 10, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice Job, but not working with my MicroModular.
Is normaly or not ?
Very thanks info about this.
Kamil
Sorry my bad English Smile
http://jlswbs.blogspot.com
http://jlswbs.wordpress.com
http://jls.wbs.cz
chresan
PostPosted: Mon Mar 10, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is normaly or not ?
Kamil
No, the MicroModular should work quite fine. Which OS / Midi interface do you use ? Under OS x you have to install a midi service provider, see http://nmedit.sourceforge.net/userpage/help.html#osx-midi
JLS
G2 patch files: 274
PostPosted: Mon Mar 10, 2008 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I using WinXP on PC platform - when set midi in/out generate this error report.
Kamil
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=In-A USB MidiSport 2x2,vendor=Unknown vendor,description=No details available] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=null,vendor=null,description=null]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
http://jls.wbs.cz
wesen
PostPosted: Mon Mar 10, 2008 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
I'm sorry to hear about the problem you encounter, we haven't done much testing under windows, except with my usb adapter baord, and it worked alright. I'll try it with windows and my midisport 4x4 and let you know when it's fixed.
Cheers, Manuel
chresan
PostPosted: Mon Mar 10, 2008 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kamil, we know that Java + MidiSport has caused problems on the linux platform. Perhaps the solution works for you too: Connect your nordmodular with the A-In/Out ports and see if this helps.
The exception you encounter is caused because Nomad could not find or open the midi device. Perhaps it is currently in use by another application. Also it is possible that your midi cables are connected wrong (MIDI-IN <-> MidiSport In and MIDI-OUT<->MidiSport Out)
JLS
G2 patch files: 274
PostPosted: Mon Mar 10, 2008 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tested in both my usb converter and same error.
MidiMan MidiSpot2x2
Motu midiExpress 128
In Clavia editor both converters working fine.
My next test download new Java and reinstaling.
http://jls.wbs.cz
chresan
PostPosted: Mon Mar 10, 2008 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
MidiMan MidiSpot2x2
There is another post with the same error. I looked through our source code and now I am 99% sure that this is a Java-JRE bug - I still have to confirm this though. Would you be so kind to post the logfile.txt which you can find in the nomad directory.
JLS
G2 patch files: 274
PostPosted: Mon Mar 10, 2008 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
INFO : logging system initialized
INFO : application root is C:\00\nomad-0-3-pre
INFO : got SAX parser factory - com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl@1f20eeb
INFO : configured, stopOnError=false, isValidating=true
INFO : plug-in and fragment descriptors registered - 15
INFO : integrity check done: errors - 0, warnings - 0
INFO : application plug-in is net.sf.nmedit.nomad.core
INFO : plug-in started - net.sf.nmedit.nmutils@0.1.0 (active/total: 1 of 15)
INFO : plug-in started - com.jgoodies.looks@2.1.4 (active/total: 2 of 15)
INFO : plug-in started - com.jgoodies.forms@1.1.0 (active/total: 3 of 15)
INFO : plug-in started - org.apache.xerces@2.9.0 (active/total: 4 of 15)
INFO : plug-in started - net.sf.nmedit.nomad.core@0.2.2 (active/total: 5 of 15)
INFO : plug-in started - org.w3.sac@1.3.0 (active/total: 6 of 15)
INFO : plug-in started - org.apache.xmlgraphics.batik@1.6.0 (active/total: 7 of 15)
INFO : plug-in started - org.mozilla.rhino@0.0.0.1_6R5 (active/total: 8 of 15)
INFO : plug-in started - net.sf.nmedit.jpatch@0.1.0 (active/total: 9 of 15)
INFO : plug-in started - org.jdom@1.0.0.xcvs (active/total: 10 of 15)
INFO : plug-in started - net.sf.cssparser@0.9.4 (active/total: 11 of 15)
INFO : plug-in started - net.sf.nmedit.jtheme@0.1.0 (active/total: 12 of 15)
INFO : plug-in started - net.sf.nmedit.jpdl2@2.0.0 (active/total: 13 of 15)
INFO : plug-in started - net.sf.nmedit.jsynth@0.1.0 (active/total: 14 of 15)
INFO : plug-in started - net.sf.nmedit.nordmodular@0.1.0 (active/total: 15 of 15)
INFO : Activating services...
INFO : Connected extensions: 7
INFO : Service implementation / Service: net.sf.nmedit.jsynth.nomad.Installer (description=JSynth installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.Installer (description=Nord Modular plugin installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nomad.core.service.initService.ExplorerLocationMemory (description=remembers explorer locations) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.NmFileService (description=Nord Modular patch 3.0) / net.sf.nmedit.nomad.core.service.fileService.FileService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.NewNordModularService (description=Nord Modular factory) / net.sf.nmedit.nomad.core.service.synthService.NewSynthService
INFO : Service implementation / Service: net.sf.nmedit.jtheme.InstallerService (description=Module Pane Installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.jpatch.nomad.InstallerService (description=JPatch Installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Setting UIDefaults ClassLoader in net.sf.nmedit.jtheme.clavia.nordmodular.JTNM1Context@163de4e: {PluginClassLoader: uid=11124894; {PluginDescriptor: uid=net.sf.nmedit.nordmodular@0.1.0}} (class org.java.plugin.standard.StandardPluginClassLoader)
INFO : Shutting down {net.sf.nmedit.nomad.core.NomadPlugin: manager=org.java.plugin.standard.StandardPluginManager@13caecd, descriptor={PluginDescriptor: uid=net.sf.nmedit.nomad.core@0.2.2}}
INFO : plug-in stopped - net.sf.nmedit.nordmodular@0.1.0 (active/total: 14 of 15)
INFO : plug-in stopped - net.sf.nmedit.jsynth@0.1.0 (active/total: 13 of 15)
INFO : plug-in stopped - net.sf.nmedit.jpdl2@2.0.0 (active/total: 12 of 15)
INFO : plug-in stopped - net.sf.nmedit.jtheme@0.1.0 (active/total: 11 of 15)
INFO : plug-in stopped - net.sf.cssparser@0.9.4 (active/total: 10 of 15)
INFO : plug-in stopped - org.jdom@1.0.0.xcvs (active/total: 9 of 15)
INFO : plug-in stopped - net.sf.nmedit.jpatch@0.1.0 (active/total: 8 of 15)
INFO : plug-in stopped - org.mozilla.rhino@0.0.0.1_6R5 (active/total: 7 of 15)
INFO : plug-in stopped - org.apache.xmlgraphics.batik@1.6.0 (active/total: 6 of 15)
INFO : plug-in stopped - org.w3.sac@1.3.0 (active/total: 5 of 15)
INFO : plug-in stopped - net.sf.nmedit.nomad.core@0.2.2 (active/total: 4 of 15)
INFO : plug-in stopped - org.apache.xerces@2.9.0 (active/total: 3 of 15)
INFO : plug-in stopped - com.jgoodies.forms@1.1.0 (active/total: 2 of 15)
INFO : plug-in stopped - com.jgoodies.looks@2.1.4 (active/total: 1 of 15)
INFO : plug-in stopped - net.sf.nmedit.nmutils@0.1.0 (active/total: 0 of 15)
INFO : shutdown done
INFO : logging system finalized
INFO : ---------------------------------
WARN : unknown listener org.java.plugin.standard.StandardPluginManager$1@1128ee5
http://jls.wbs.cz
Audio files: 215
G2 patch files: 92
PostPosted: Mon Mar 10, 2008 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
First of all:
Hail the Master banana
for this amazing piece of work that you have created. Judging by the screencasts this is a slick product indeed, surpassing the G2 in parts.
I got it working on my OSX 10.4.11 after a little hassle. I already had mmj installed (I've fiddled a bit with MIDI from Java earlier), but that didn't seem to agree with Nomad, so I had to remove the existing extension and install your bundled stuff instead. Then i got an error message but after a couple of trys I got it connected to my NM Key. Woohoo! Very Happy
The only remaining issue now is that I don't see any modules in the left-hand pane. I can right-click on the grey background and add modules that way. I tried clickin more and the + - icons. I'm going to fiddle a bit more with this tomorrow - can't wait to try out those macros!
Great work!
/Stefan
gomidas
G2 patch files: 6
PostPosted: Mon Mar 10, 2008 3:31 pm    Post subject: Re: Nomad 0.3 pre-release available for DL Reply with quote  Mark this post and the followings unread
INCREDIBLE!!!AMAZING WORK!!!!
AND ABOUT MACROS...I WAS ABOUT TO CRY...WE SHOULD HAVE THIS FEATURE FOR THE G2 A LONG TIME AGO!!!! FOR MY NORD MODULAR, IT IS A SECOND LIFE!!!
BIG THANKS TO THE TEAM wow! Apple Linux Microsoft well-done well done
chresan
PostPosted: Mon Mar 10, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Stephan,
thanks for pointing this out. This happens when making code changes 5minutes before releasing Very Happy
We fixed the problem and updated the release. Just download Nomad again and you will find all modules where they should be.
Christian
m:o
PostPosted: Mon Mar 10, 2008 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great release guys but besides that Nomad won't recognize my Midi Interface, how do i delete patched cables ?
chresan
PostPosted: Mon Mar 10, 2008 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Either right click on the connector and then select "Disconnect" in the menu or double click a connector and drag'n'drop the cable into the nirvana Smile The cables themself are not clickable.
m:o
PostPosted: Mon Mar 10, 2008 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's not working (both ways). no contextmenu on right-click. also when i right-click on the backgroung of the editor (i think you can access module menus this way) nothing happens.
hinotori
PostPosted: Mon Mar 10, 2008 9:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
after some messing about with plumstone (no luck) and your midi bits (also no luck) i installed mmj and it works. . . AMAZING WORK !
(btw..im using an ibook g4 to connect to an NM1 keyboard using a midisport 2x2 .)
many many thanks for all the time youve put into this . the additions will really speed up the creative workflow . . . great stuff . .. now back to the joys of patching Smile
EIII
PostPosted: Tue Mar 11, 2008 2:04 am    Post subject: lucky ? unlucky ! Reply with quote  Mark this post and the followings unread
Firt of all , huge thanks for the hard works.
i'm on Xp , using a midisport 2*2 as a midi interface for the Nm1.
got the same error :
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
I hope you will find a way ! i'm dying to start on working with the new release
Cheers :!
Audio files: 215
G2 patch files: 92
PostPosted: Tue Mar 11, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
chresan wrote:
Hi Stephan,
No problem, you fixed it quickly enough. Smile I am eager to get home from work to try out Nomad some more.
/Stefan
frabo
PostPosted: Tue Mar 11, 2008 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
seems to be a very good work !
But I did not get a wire to my NM-Keyb. Sad
I get always a Midi Timeout error!
I'm on 0sx 10.4.11 and I tryed it with some devices:
- RME Fireface
- Novation remote SL
- evolution EV-10 (single midi-interface)
and I tryed with osxmidispi.jar and with mmj.jar
her is the error log:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 10 more
thank you for any help
Confused
nathan
PostPosted: Tue Mar 11, 2008 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
hey !
same as mine i think.
check the other topic.
not that i figured it out yet. ( well, manuel is trying to) Smile
frabo
PostPosted: Tue Mar 11, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
I got it ! Yess !
I changed the midi clock to "EXT" in the NM-Keyb. !
It seems to get in trouble when the NM send all the time the Clock sysex
Wink
wesen
PostPosted: Tue Mar 11, 2008 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah good, that may be a reason why it gets into trouble. I'll check this Smile
nathan
PostPosted: Tue Mar 11, 2008 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
haha!!! Very Happy
yes! thats it!
all working here now!
thanks a lot guys!
and Wesen>>> thanks for your time and offcourse all the developmenttime yuo put into this editor!
wesen
PostPosted: Tue Mar 11, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome. You really have to thank christian for this, I must admit my goal was a little bit selfish, as I really wanted to edit nord patches in a comfy way. So I pushed christian to finish all the stuff and added some UI ameliorations for comfyness. And macros definitely rule Smile
