Control Change
Page 1 of 1 [5 Posts]
Plasticman
PostPosted: Mon Apr 07, 2008 12:36 pm    Post subject: Control Change
Subject description: Question about the controlChange function in the StkInstrument class
Code:
.controlChange - ( int number, float value ) - assert control change - numbers are instrument specific, value range: [0.0 - 128.0]
Just a question about this function... As this is specific to each StkInstrument, is there a list somewhere of what the int value for each control is? Are they in the order shown for each class on this page? Also, can that function change the freq control?
Thanks
radarsat1
PostPosted: Mon Apr 07, 2008 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Look on the page you linked, each instrument has a list of control change values, for instance for BandedWG:
Control Change Numbers:
- Bow Pressure = 2
- Bow Motion = 4
- Strike Position = 8 (not implemented)
- Vibrato Frequency = 11
- Gain = 1
- Bow Velocity = 128
- Set Striking = 64
- Instrument Presets = 16
- Uniform Bar = 0
- Tuned Bar = 1
- Glass Harmonica = 2
- Tibetan Bowl = 3
Plasticman
PostPosted: Wed Apr 09, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Touché, thanks.
PostPosted: Wed Apr 09, 2008 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Also; typically you don't need to use those. They are inherited from the STK but (nearly?) all are copied to more meaningful, readable and ChucKian member functions.
while(!machine.crash() ) <<<"all is well">>>;
Plasticman
PostPosted: Wed Apr 09, 2008 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
It's actually more suited to my puroses than the member functions; it's being used as the backend to a synthesizer which communicates using OSC, so the (int, float) parameters are perfect for the sliders on the front end. Thanks for the suggestion though.
