Interpolating scanner Canned LM394
Page 1 of 1 [3 Posts]
defex
PostPosted: Fri Sep 17, 2010 6:57 pm    Post subject: Interpolating scanner Canned LM394 Reply with quote  Mark this post and the followings unread
I got the Interpolating scanner boards, and found some metal canned LM394s,
I thought they would fit right in place of the DIP8 ones (which they will physically, ignoring the bottom 2 unused pins) and audiophools will tell you that metal canned components sound better Wink
but looking at the National data sheet I see some diodes in the canned version which do not appear to be in the DIP version.
bottom of this PDF
http://www.national.com/ds/LM/LM194.pdf
Is this just them drawing them in because they have room for them or could it cause a problem in the circuit? I really cant imagine them making the canned version electrically different.
Just being sure before i even start the interpolating scanner, so i will have time to get plastic ones if i need to. (i am still finishing up the living VCO. very very nice!)
Thanks
DeFex
Girts
PostPosted: Sat Sep 18, 2010 11:07 am    Post subject: Re: Interpolating scanner Canned LM394 Reply with quote  Mark this post and the followings unread
I can't comment on the data sheet differences but Dave has built Scanner using LM394 cans.
http://modularsynthesis.com/jhaible/scanner/jhscanner.htm
defex
PostPosted: Sat Sep 18, 2010 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, someone did it and it worked, thats good enough for me Smile thanks!
