CGS Power Supply Questions
Page 1 of 1 [11 Posts]
hopelessennui
PostPosted: Sun Jun 29, 2008 2:46 am    Post subject: CGS Power Supply Questions Reply with quote  Mark this post and the followings unread
Hello all!
I had a couple questions about the CGS66 PSU.
When i bought it i thought it i thought it was like the MFOS psu where you just use an AC wall wart adapter, but in the directions Ken talks about using a center tapped transformer. Its a bit over my head. I tried finding a center tapped transformer on mouser and got lost. Can someone point me in the right direction, or even better a link to the right one? Also how would I wire the transformer to the AC mains?
Ken mentions "where possible use a wall wart"
Can i use a wall wart instead?
Thanks a million.
andrewF
PostPosted: Sun Jun 29, 2008 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
sounds like you will be better off with a 18VAC wallwart for now.
from Ken's page -
"it is possible to use a wall-wart between CT (the 0V connection on the PCB) and one 18V AC connection. The required pads are marked with large white circles. The result will be half wave rectification. If you use larger caps (3300uf) and limit the loading, you will be okay."
hopelessennui
PostPosted: Sun Jun 29, 2008 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
is half wave retification bad? any idea of how much load it could handle? or how many mA wall wart i should use?
Thanks
otherunicorn
PostPosted: Sun Jun 29, 2008 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Full wave is better than half wave, but that doesn't mean half wave is "bad". You would want a wall wart with at least 700ma. The higher the better. If you can find a 1A or a 1.2A, all the better.
http://www.cgs.synth.net/
Kartoshka
PostPosted: Wed Jul 16, 2008 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another cgs66 question: does those lines (enlightened on the picture) meant to be bridged with piece of wire?
 Filesize:  51.6 KB
 Viewed:  547 Time(s)
otherunicorn
PostPosted: Thu Jul 17, 2008 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Those are links.
zthee
PostPosted: Fri Jul 18, 2008 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
You might wanna flip that capacitor; as it says on the CGS website "The 10uF capacitor beside the -15V pin of the 4 pin MOTM style connector is also shown on the overlay backwards."
I think?
 Filesize:  98.9 KB
 Viewed:  496 Time(s)
otherunicorn
PostPosted: Fri Jul 18, 2008 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think?
And rather annoyingly it is still backwards on the REV1.1 board....
Kartoshka
PostPosted: Sat Jul 19, 2008 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
true, how could i miss that. thanks guys again.
Tronato
PostPosted: Wed Aug 13, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Ken mentions that he cut a track and I can see that he did. However he also mentions that a link has to be added right next to the cut that is indicated by a black marker line.
Did you add that link?
TRON
otherunicorn
PostPosted: Fri Aug 15, 2008 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Tronato wrote:
Hello!
TRON
That is only for the first version.
