Lead and midi send
Page 1 of 1 [8 Posts]
one
PostPosted: Thu May 15, 2008 2:25 pm    Post subject: Lead and midi send
Subject description: Midi send and receive
Hi, how do I program the Nord Lead 3 to send and receive midi data on the Cubase Studio 4? Rolling Eyes
Sincerely jours
One
Wout Blommers
Audio files: 91
G2 patch files: 11
PostPosted: Fri May 16, 2008 12:10 am    Post subject: Re: Lead and midi send
Normally the NL3 is set to send and receive Midi data by default. I'll check the Manual tonight about Midi on/off settings in [system]
Wout
one
PostPosted: Mon May 19, 2008 8:28 pm    Post subject: Re: Lead and midi send
Hi, I have tried to find out it whit no luck Sad
Wout
Wout Blommers
Audio files: 91
G2 patch files: 11
PostPosted: Tue May 20, 2008 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there anyway you can check the Midi coming from the Lead using another Midi device? Have you checked the Midi Channels both in the synth and CuBase?
Are all cables connected right?
Wout
nordragious
PostPosted: Tue May 20, 2008 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
check the MIDI local on/off setting (if that's not what you mean Wout?)
Submenu - No thanks.. Let's tweak some knobs!
Wout Blommers
Audio files: 91
G2 patch files: 11
PostPosted: Tue May 20, 2008 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not exactly, because the NordLead always react to incoming Midi. Local Off means only the Keyboard and the Panel. 'one' has troubles with the connection between the computer and the synth: they don't communicate.
Anyway, I should check this also Smile
Wout
nordragious
PostPosted: Wed May 21, 2008 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
maybe i should read the whole topic first Wink
Wout Blommers
Audio files: 91
G2 patch files: 11
PostPosted: Wed May 21, 2008 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
It could be the Midi channel is set to 'off', in which no Midi is send nor received.
Local off means the solund generation part of the synth doesn't react to the Keyboard anymore, but there is still Midi Out to the Midi port.
I can't do anything to the settings of CuBase, so, one, do other synths work well receiving or sendin Midi? If so, check the Midi channel settings of the NL3. Maybe they are set to 'off'.
Wout
Once You Know, You Newegg
