annoying exception - associative array
Page 1 of 1 [6 Posts]
fraukefroehlich
PostPosted: Wed Jun 04, 2008 10:41 pm    Post subject:  annoying exception - associative array Reply with quote  Mark this post and the followings unread
hi there...
since i've lost hours dealing with this issue and i didn't get any further, i decided ask for help...
i tried the following code:
Code:
//initializing lengths
"v" => string v; //quarter note
"a" => string a; //eighth note
"s" => string s; //sixteenth note
string noteDurations[]; //durations of a given music composition
int markov[][]; //the array holding the markov chain
[s,s,a,s,v/*....etc.*/] @=> noteDurations;
for(0 => int i; i < noteDurations.cap() - 2; i++){
    noteDurations[i] + noteDurations[i+1] => string pre;
    noteDurations[i+2] => string post;
    markov[pre][post] => int tmp;
    tmp + 1 @=> markov[pre][post];
now what i try to do is building a markov chain from the durations of a given music composition.
a markov chain (of second order in this case) determines which notelength comes next, regarding the two predecessors...
i. e.:
the array notedurations says: index 0 and index 1 are "ss" (predecessors) to which follows an "a" (successor). since this is the only successor for those predecessors in my music composition, the probability for this relation is 100%. that just means, if "ss" is recognized, an "a" has to be thrown next, etc.
ok, tried to solve this with an associative array, but it throws the following exception:
Code:
[chuck](VM): sporking incoming shred: 1 (exception.ck)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189be370)...
[chuck]:(10:ALL!!): adding 'Chuck_String' (0x189be370)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189d1190)...
[chuck]:(10:ALL!!): adding 'Chuck_String' (0x189d1190)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189b7540)...
[chuck]:(10:ALL!!): adding 'Chuck_String' (0x189b7540)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189b7840)...
[chuck]:(10:ALL!!): adding 'Chuck_Array4' (0x189b7840)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189b78c0)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189b7940)...
[chuck]:(10:ALL!!): adding 'Chuck_String' (0x189b7940)...
[chuck]:(10:ALL!!): adding 'Chuck_Object' (0x189b79b0)...
[chuck]:(10:ALL!!): adding 'Chuck_String' (0x189b79b0)...
[chuck](VM): NullPointerException: (array access) in shred[id=1:exception.ck], PC=[64]
[chuck](VM): (array dimension where exception occurred: 0)
[chuck]:(8:FINER!): dumping shred (id==1 | ptr==0x189b7770)
[chuck]:(8:FINER!): releasing dumped shreds...
[chuck]:(9:FINEST): freeing 'Chuck_VM_Shred' (0x189b7770)...
any ideas?
thx
Frostburn
Audio files: 9
PostPosted: Thu Jun 05, 2008 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
First I thought the problem was that you didn't initialize the array properly but it seems that multidimensional arrays are broken at the moment...
Code:
int aa[0][0]; //Dimensions need to be specified
3 => aa["Chuck"]["Norris"]; //Crash & Burn...
To boldly go where no man has bothered to go before.
fraukefroehlich
PostPosted: Thu Jun 05, 2008 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Frostburn wrote:
...but it seems that multidimensional arrays are broken at the moment...
... which means...?
Frostburn
Audio files: 9
PostPosted: Thu Jun 05, 2008 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm afraid it's a bug and doesn't work.
kijjaz
PostPosted: Fri Jun 06, 2008 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
float noteDurations[0];
4.0/4 => noteDurations["v"]; // define quarter note
4.0/8 => noteDurations["a"]; // define eighth note
4.0/16 => noteDurations["s"]; // define sixteenth note
Can this kind of defining note durations help you access the durations the way you'd like to?
(for example, noteDuration[v] would be 1.0, when v is defined a string "v")
fraukefroehlich
PostPosted: Sat Jun 07, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm.. .quickly thinking about this option i guess it would allow a quite nice workaround, yes.
but i've already come up with a different workaround. i'll post the code after the 13th Wink
however, thx for the clue!
u said it man... nobody chucks with the jesus...
Top Selling Products! CLICK HERE!
