Aftertouch sensitivity
Page 1 of 1 [3 Posts]
Rix
G2 patch files: 25
PostPosted: Tue Aug 10, 2004 7:17 am    Post subject: Aftertouch sensitivity Reply with quote  Mark this post and the followings unread
Is there a way to change the aftertouch sensitivity or curve on the G2?
Since I am originally a piano player I feel the keys respond to aftertouch too soon....
On my keyboard (from a Japanese manufactorer with a boys name) you could select several velocity sensing curves.
Richard
Audio files: 169
G2 patch files: 319
PostPosted: Tue Aug 10, 2004 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
The way to do that is to couple the aftertouch to a constant module (assigning its knob to the aftertouch associated morph) and then use some shaper and or offset and or multiplication to get it respond the way you want it to. The constant's output can be coupled to a modulation input, probably the modulation input of an ADSR.
See, its modular !
Jan.
Rix
G2 patch files: 25
PostPosted: Tue Aug 10, 2004 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
OK Jan, I can see how that would work on the internal sound.
I was not clear that if I want to use the G2 as a sort of masterkeyboard, steering my XV-5080 and other stuff.
But I guess in the same line of thinking it must be possible to make some midi routing patch and thus control the midi out flow.....
Richard
