tap tempo delay patch for clock, delay & LFO
Fozzie
G2 patch files: 49
PostPosted: Thu Sep 02, 2004 11:15 pm    Post subject: tap tempo delay patch for clock, delay & LFO Reply with quote  Mark this post and the followings unread
Here is a patch, based on the starting work of Xavier Tribolet, that will sync a clock generator, delay module and LFO module (all slightly roughly) to the tapped tempo on the c6 note (two taps set tempo). Bpm values of 50-214 are possible, in 95 steps.
Enjoy, Paul.
Edit: must be in slot A to work properly (because of midi cc for clock generator)
tap_tempo_XT_PV_tempodelay.pch2
Tap tempo patch that syncs clock, delay and LFO to rythm on note c6 (two taps necessary)
 Filename:  tap_tempo_XT_PV_tempodelay.pch2
 Filesize:  5.88 KB
 Downloaded:  1040 Time(s)
