 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
connection trouble to micro on mandriva via ua-100
astroconst
PostPosted: Sun Mar 08, 2009 9:36 pm    Post subject: connection trouble to micro on mandriva via ua-100 Reply with quote  Mark this post and the followings unread
I am trying to run nomad 0-3_2 on Mandriva linux using the MIDI interface of my Roland UA-100 and connect to my micro modular. I have tried both jre 1.5.0_11 and 1.6.0_12. The editor always comes up fine, but can never connect to the synth when I press the connect button. The UA-100 has two MIDI inputs and two MIDI outputs, and I've tried both sets.
When I press the connect button, the Connection Settings page comes up. Both the Input and Output are set to:
UA100 [hw: 1,0] (1) (current)
with the other options being (2) and (3). In all cases, the text below is:
Descrption UA-100, USB MIDI, UA-100
Vendor ALSA (http://www.alsa-project.org)
Version 1.0.12
I have tried setting both to (1), both to (2), both to (3), one to (1) and one to (2) (and vice versa), all to no avail.
I noted the following text in the release announcement:
Before starting the editor open the file
nomad/conf/application.xml
with a text editor and change the line
<entry>4</entry>
to
<entry>1</entry>
but can find no application.xml file.
OH YOU'VE GOT TO BE KIDDING ME.... okay, it's a good thing, but I just got it to work!!!!! I was just going to fire it up again to generate a logfile.txt to post, and I tried having the input set to (1) and the output to (3), and that did the trick!!
Let this be a lesson (and the reason I'm going to post this anyways): creating a detailed enough bug report is not just useful to the developers, it can sometimes help you solve the problem yourself!
-Jer.[/quote]
