Audio files: 215
G2 patch files: 92
Posted: Sun Oct 11, 2009 1:54 pm Post subject:
Some questions regarding ground |
Blue Hell mentioned in a topic regarding patch cables that it makes sense to only connect the tip of 1/4" jacks when using them as patch cables on a modular. This to prevent ground loops (I interpret this to be connections between the ground nodes of modules other than via the power supply).
What kind of nasty effects can you get from ground loops? Hum or worse? I'm currently using a mixture of bi- and uniwired patch cables (haven't made enough uniwires yet). Are you more prone to nasty ground loops if you make many extra ground connections or just one between two modules?
I'm also wondering if all devices with multiple out- or inputs use this technique with common ground for all connections. Case in point: I'm using my MOTU Ultralite to send several CVs to the modulars. Will it be enough to just make one of these connections with a biwired cable (thus establishing a common ground level), or should I use two wires for all connections between the Ultralite and the modular? Might there be risk of ground loop if the reverse is the case?
I've already patched a lot and it all seems to work nicely (no hum at least), but it's always nice to have the theory straight for future issues.
@soundcloud @Flattr @myspace A blog home - you can't explain music |
Joined: Apr 03, 2004 Posts: 19596 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Mon Oct 12, 2009 11:13 am Post subject:
The wikipedia article about ground loops seems ok in explaining how ground loops can cause hum in audio circuits.
For patching a modular synth this is a bit academic considering the large signals being involved ... but on my old formant I did use a mix from unshielded cables, shielded cables with shield connected only at one side and yet other cables would be shield connected on both sides ... thing is it's way easier to make unshielded patch cables and way easier to buy cables having a ground connection on both sides. _________________ Jan |
Audio files: 215
G2 patch files: 92
Ricko
Joined: Dec 25, 2007 Posts: 154 Location: Sydney, Australia
Posted: Mon Oct 12, 2009 4:21 pm Post subject:
In theory you could also just have a low value resistor (eg 470 ohm?) on the 0v/ground line of the cable. That can be enough to dissuade oscillations from loops.
It certainly works for loops for stereos. (I have this at the moment on my CD player for example; it worked a treat.)
When I played in bands we always had a stop of earth lifting power adapters, with the third pin removed (obviously not a US issue). If we had hum in our systems we would try the adaptor. Always worked. |
Audio files: 215
G2 patch files: 92
Sound
Posted: Tue Oct 13, 2009 2:02 am Post subject:
| Antimon wrote: | Ah wikipedia, of course. Thanks!
/Stefan |
Oh yes! Wikipedia is this kind of things that make this world better, not only because the tones of knowledge available there, also because its philosophy.
Like my friend Jesulin would say- in two words: awe some.
In the end of the wiki article there are these links to Rane notes:
http://www.rane.com/note110.html
http://www.rane.com/note151.html
I hardly recommend read it. I did it yesterday and although it open me new doubts, I think it put you in the correct way to understand this phenomenon .
(by the way all the notes I have read from Rane are pretty good IMHO)
For now I only would say that is good increase the mm2 of the ground conductor.
I had noise on my modular because I had the connection module to the power supply bus board, with 0.25mm2 cable with little 4 pins connectors.
One pin positive, one pin ground, one pin unused, one pin negative.
I solved this adding another ground cable in the unused pin.
I think it is because you decrease the resistance of the conductor.
I should made new connectors with 0.5mm2 cable at least.
Regards. |
