<on air> Asheville electro-music festival live stream
Notepad++ Syntax Highlighter
Page 1 of 1 [11 Posts]
vadimred13
PostPosted: Tue Mar 10, 2009 7:27 am    Post subject: Notepad++ Syntax Highlighter Reply with quote  Mark this post and the followings unread
I've configured a ChucK syntax highlighter for Notepad++:
To use - download the XML to your Notepad++ Application Data folder. For windows, this is C:\Documents and Settings\<user>\Application Data\Notepad++
If you already have a custom language definition in Notepad++, you're gonna have to do some XML merging (fun stuff). Enjoy!
PostPosted: Tue Mar 10, 2009 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! I have a NP++ setup that works but I was -so far- unable to get it out of there. I'll try yours as well.
Lovely first post, welcome on board!
vadimred13
PostPosted: Wed Mar 11, 2009 9:08 pm    Post subject: Updated Reply with quote  Mark this post and the followings unread
I've configured AutoComplete functionality for Notepad++.
Copy this XML file into your APIs folder in your Notepad++ install directory. For Windows, this is: C:\Program Files\Notepad++\plugins\APIs
Make sure that you have AutoComplete enabled in your Notepad++ preferences.
I've also updated the syntax highlighter (from the first post) to also highlight functions in the Std, Math, and Machine libraries.
PostPosted: Thu Mar 12, 2009 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
That's really nice! Did you find a way to have keyboard shortcuts for running ChucK from NP++ as well?
vadimred13
PostPosted: Thu Mar 12, 2009 11:35 am    Post subject: Running ChucK from Notepad++ Reply with quote  Mark this post and the followings unread
Well, since you ask - yes. Copy this batch file to your drive:
Then edit it to point to your chuck.exe. In Notepad++, navigate to Run, Run... (or hit F5) to bring up the Run... dialog. Once there, paste this command in there:
"location_of_where_you_saved_the_above_script" "$(CURRENT_DIRECTORY)" "$(FILE_NAME)"
From there, if you click Save, you can bind this command to a key/key combination.
So, for me the command is:
"C:\ChucK\runChucK.bat" "$(CURRENT_DIRECTORY)" "$(FILE_NAME)"
because my runChucK script lives in C:\ChucK
It actually shouldn't be too difficult to set up some kind of script/macro, or even write a little launcher program to be able to add/remove/replace shreds on the virtual machine from within Notepad++, but I'm at work right now, so I'll work on that when I get home. It definitely would be useful...at least until the new version of miniAudicle comes out...if it ever does Smile
PostPosted: Thu Mar 12, 2009 12:15 pm    Post subject: Re: Running ChucK from Notepad++ Reply with quote  Mark this post and the followings unread
Way cool.
PostPosted: Mon Apr 20, 2009 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally got round to playing with these.
Some issues; In your language highlight settings the "folder" operators never seem to mark the end of the folding block. I use "{" and "}" for those and that way it works for me. Does this work for you?
Also; I can't get the auto completion to work right; it will recognise words I used elsewhere in the code and offer those as well as some that seem to come from some other language but not "SinOsc" and so on. Any idea on what I might've done wrong there?
vadimred13
PostPosted: Mon Apr 20, 2009 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately, when it comes to code folding, Notepad++ makes you choose one of 2 solutions. Either enable code folding, but give up that lovely brace matching/highlighting functionality, or the other way around. As long as you specify '{' and '}' as activated operators - code folding will not happen. If you unspecify them, and add them to the folding open and close symbols - folding will happen (at the cost of matching braces). I chose to give up folding, because I'd rather have the matching braces. Let me know if you get both folding and brace matching working...
As for the auto-completiong not working - make sure that in your autocomplete settings, you have Function completion selected (not word completion). In my settings, I checked the Enable Auto-Completion on each input and the Function parameters hint on input checkboxes, and selected the Function completion radio button
Let me know if that doesn't do it for you.
-Vadim
PostPosted: Tue Apr 21, 2009 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I think you are right. I don't see why it needs to be that "either/or". Anyway, I like folding better than brace matching, I think. Sometimes I make it fold and find the missing/extra brace based on that.
It works now, I had to update NP++; my version was quite old already, I had no idea there were that many updates to it, it looked quite mature to me.
BTW, what is your word-list based on? I think it lists a few things, like "super" and "implements" that I don't think are used in ChucK.
vadimred13
PostPosted: Tue Apr 21, 2009 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
It's based on the reserved keywords from the ChucK language spec.
No, they don't do anything yet, but I'm guessing that they are reserved for possible future use.
PostPosted: Tue Apr 21, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, yes.
Yeah, the development of the whole class system was always on The List behind garbage collection and GC took a bit longer to arrive than anyone thought. It seems quite tricky.
