 Forum index » Instruments and Equipment » Soft synths
Audiomulch, recording on the computer ?
Page 1 of 1 [4 Posts]
Patchmouse
PostPosted: Mon May 18, 2009 7:08 am    Post subject: Audiomulch, recording on the computer ? Reply with quote  Mark this post and the followings unread
Hi, I've been using Audiomulch for some time now, but have recently gone over to recording completely in the box, this is fine for my other app's, except I can't use my Audiomulch ! AM isn't a VSTi, so, short of buying an external recorder just to record AM I don't know what to do ?
Patchmouse.
Audio files: 284
PostPosted: Wed May 20, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tony!
You could use a plugin within AM to record its output. Take a look at Voxengo's Recorder VST, that is the simplest solution I can think of...
http://www.voxengo.com/product/recorder/
It's free and worth a shot. Very Happy
Muied Lumens Base Star
Patchmouse
PostPosted: Wed May 20, 2009 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Muied Lumens wrote:
Hi Tony!
Lumens ! how are you old chap ! Very Happy
Thanks for the link, I've downloaded the VST version, is that OK ?
I'll give it a try, be great if it works !
Take care, I'll no doubt bump into you here again !
Patch Mouse.
Patchmouse
PostPosted: Thu May 21, 2009 1:19 am    Post subject: Ureka !
Subject description: Recording...
I've found the solution ! should any other AM users out there have the same problem.
I don't actually need the Voxengo recorder. Because I haven't had to do this before, I didn't notice that the "Sound Out" module in Audiomulch has a recording facility with which you can save the output WAVE to anywhere on your computer. So, problem solved ! This was the one and only thing that has stopped me from being able to use the computer completely on it's own Very Happy
Patch Mouse
