 Forum index » Instruments and Equipment » Nord stage
Nord Electro 3 Sound Library
Page 1 of 1 [2 Posts]
dougfarrar
PostPosted: Fri Aug 14, 2009 7:14 pm    Post subject: Nord Electro 3 Sound Library
Subject description: How many sounds can I change?
The electro 3 manual says "....Each
and every piano and sample in the Nord Electro 3 can be replaced by you." and "All of the 128 factory Programs of Nord Electro 3 can be replaced."
So does this mean I can have a variety of sounds from the sample library loaded at once? Can I get rid of the electric piano and harpsichord and have a pad and glockenspiel in addition to the stock mellotron?
Thanks for the help
skipgilles
PostPosted: Thu Sep 10, 2009 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
in fact, you can delete all sounds from the electro (not the organs, these are no samples). The fewer piano's you have, the more other sounds you can store. The only limit is memory.
About thee programs: these are just stored combinations of a <sound> + <effects> , that are easily accessible in two banks (A and B) with 64 slots. So here you could store, e.g., your <wurlitzer> with <panning> in slot B52.
Gilles
Niio1
