Cardinen
Posted: Tue Sep 15, 2009 6:42 am Post subject:
VCA PCB Layout link down |
first post here, but i've read this forum sooo many times...
I'm not able to open the PCB layout of the yusynth VCA.
Please, can you fixes it ??
Tank's Yves, your projects are just incredible! |
yusynth
Posted: Thu Sep 17, 2009 1:44 am Post subject:
Which link are you mentionning ? I checked the PCB file links and all is working fine here.
May be there was traffic jam on the server when you tried? Try again and let me know if you still encounters difficulties I will email you the PCB file. _________________ Yves |
Cardinen
Posted: Thu Sep 17, 2009 7:39 am Post subject:
Hi Yves,
I've try so many times since 2 weeks, but is always the same, and only whit the VCA layout (the PCB ready to print for p'n'p). I know, is strange, but this is the only one i can't open; maybe is a my problem.
Please if you send me it i'll be very glad.
unpobubba (at) yahoo.it
TANK'S |
magman
Joined: Feb 04, 2009 Posts: 352 Location: Liverpool, UK
Posted: Thu Sep 17, 2009 8:15 am Post subject:
Yves,
I've just check as well, out of interest.
For the VCA PCB Design I just get a filename displayed (http://www.yusynth.net/Modular/Commun/VCA/VCA-PCB.jpg) rather than the image being displayed. All other images on the page appear to display correctly.
Regards
Magman |
yusynth
Posted: Thu Sep 17, 2009 9:37 am Post subject:
| magman wrote: | Yves,
Regards
Magman |
Weird... I copy-pasted the url in your message into my web browser and after a few seconds the image popped up normally !
May be something wrong in the encoding of the image that makes it not compatible with some browsers. I will create a new file and see if the problem is still there. _________________ Yves |
yusynth
Posted: Thu Sep 17, 2009 9:41 am Post subject:
OK I created a new file, can you retry and let me know if it works now. In the meantine I email the file to Cardinen _________________ Yves |
Cardinen
Posted: Thu Sep 17, 2009 11:09 am Post subject:
I still have the problem whit firefox but not whit safari (i'm on mac).
Weird
However tank's for the mail and for the support.
...is soldering time..  |
magman
Posted: Thu Sep 17, 2009 3:30 pm Post subject:
Yves,
Never thought of the potential browser issues, just tried it in IE and the link works, but it still doesn't work in Firefox.
I don't profess to be an expert in HTML, but I just had a quick look at the code via Firefox and I spotted one difference that may be relevant.
The following is the source for the VCA frame in question
| Code: | style="text-align: center; vertical-align: middle; color: rgb(255, 255, 255); width: 150px;">
<center><b>PCB design</b><br>
<br>
<span><a href="../../Commun/VCA/VCA-PCB.jpg"><img alt="" src="../../Commun/VCA/VCA-PCB-thumb.gif"></a></span><a href="../../Commun/STEINERVCF/VCF-PCB-3096.jpg"><br>
</a><a href="../../Commun/VCA/VCA-PCB.jpg"><img alt="" src="../../../images/loupe.gif"></a><br>
<br>
</center>
</td>
<td
For comparison, here's the similar source code for the Dual Pulse Delay frame:
| Code: | style="text-align: center; vertical-align: middle; color: rgb(255, 255, 255); width: 170px;">
<br>
<a href="../../Commun/PULSEDELAY/pulsedelay-PCB.jpg"><img alt="" src="../../Commun/PULSEDELAY/pulsedelay-PCB-thumb.gif"></a><br>
<a href="../../Commun/PULSEDELAY/pulsedelay-PCB.jpg"><img alt="" src="../../../images/loupe.gif"></a></center>
</td>
<td
It looks like a href for another image has snuck into the code for VCA and apparently the other browsers are ignoring it.
Hope this helps clear the issue.
Regards
Magman |
yusynth
Posted: Thu Sep 17, 2009 11:04 pm Post subject:
Regards
Magman |
Thanks a lot Magman, I did not check the html code since it was working on all the browser I am using. I will remove this hidden reference to a phantom image and it should fix the problem.
Regards
Yves _________________ Yves |
Cardinen
Posted: Fri Sep 18, 2009 11:35 am Post subject:
| Yes, now it work ! |
