Controlled Intervals Sequencer - Needs Your Help!!
TEMAS
PostPosted: Sun Jan 24, 2010 10:46 am    Post subject: Controlled Intervals Sequencer - Needs Your Help!!
Subject description: Control the duration of each step of the sequence.
Hi. I'm pulling my hair out trying to solve this problem; maybe someone can help.
Here's what I'm trying to achieve:
1. Press a key momentarily to start the sequence. (Please use Key E3 on the keyboard).
2. Control the duration of each step of the sequence using a clock that can be synced to the master clock or LFO (not measured in ms)
3. Have the option to interrupt the active sequence and restart a new sequence each time a new key is pressed on the keyboard.
The problem I'm having is that I'm using Delay Clock modules to measure the duration of the steps and when I restart the sequence sometimes one of the Delay Clocks still has a click stored in its delay memory, which means that the previous sequence continues after I've restarted a new one.
As far as I can work out there's no way to 'clear' the Delay Clock's memory. If anyone can help find a solution to this I'd be very happy.
Thanks.
Controlled intervals.pch2
 Filename:  Controlled intervals.pch2
 Filesize:  2.75 KB
 Downloaded:  444 Time(s)
Trevor Masterson
AmbiphonicDSP
