deadbeat
Posted: Wed Feb 24, 2010 3:55 pm Post subject:
Hi Everybody - Few Questions also ! |
Hi everybody ! I'm pretty new on this forum.. So i wanted to tell you i'm really happy to have discovered your work, ans such knowledge..
Well, i come from circuit bending, and i discovered cmos chips and 4000 series when i started building noises boxes.
And i look forward now.
First at all, sorry for my poor english, i think i'm not really good, i hope everybody will understand me.
I'd lilke to ask you several questions :
How can i use cv signels in my lunetta ? Is there better chips for them or not ? ( I'm thinking of using sequencers... )
Can i use different power supply for different lunettas module, or use some noises boxes which run with 12 or 15v wiht 9v modules ?
What are differencies between CMOS 4000 Series, 40000 Series and 4500 Series ?
Well, lots of stuff, i hope you'll answer me.
See you soon, Deadbeat |
deadbeat
Posted: Wed Feb 24, 2010 4:47 pm Post subject:
just for telling you that i'v alreaady read the lunetta document written by Mr Gonzales.
It helped me a lot, but is there somebody who could help me with the power supply question ?
How do you manage for power supplying biggest lunetta projects ?
Thanks for your answers !
cheers, deadbeat _________________ http://h.a.k.free.fr/
http://virb.com/dead_beat
http://virb.com/bend_over_boysfriends |
droffset
Joined: Feb 02, 2009 Posts: 480 Location: new zealand
RF
Joined: Mar 23, 2007 Posts: 1482 Location: Northern Minnesota, USA
Audio files: 28
Posted: Thu Feb 25, 2010 8:25 am Post subject:
Hi Deadbeat
..just wanted to say 'Hi" and say it's nice to have you here
Myself, I don't use any of my sequencers or other CV's from the modular in my Lunetta - but I guess you could use a gate sequencer or LFO's to clock things.
Think a little differently about the Lunetta than a modular synth with CV voltages.
I have many sequencers - MFOS, Klee, Baby 10's...but I don't have any sequencer that can do the wonderful things that a couple CMOS chips can do for unusual and interesting changing patterns and beats.
have fun!
bruce
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
Psyingo
Posted: Sat Feb 27, 2010 8:12 pm Post subject:
Re: Hi Everybody - Few Questions also ! |
| deadbeat wrote: | Hi everybody ! I'm pretty new on this forum.. So i wanted to tell you i'm really happy to have discovered your work, ans such knowledge..
as far as lunettas RECIEVING cv, there isn't alot of stuff for doing so, there are some lunetta-esque vco's and what not but signals inside lunettas are digital, so gates or triggers would work nicely from external gear.
I would try to power my creations using similar power. my mdular runs off 9v, i have my lunetta a bit higher then that, running off 12v, and its fine. another lunetta is at 9v. i sometimes worry of going over voltage on the lunetta since cmos apparently doesnt like voltages coming in over the system power.
and as far as differences between 40xx, 45xx and 401xx i have no idea, i figured they were the same series, but theres must be some kind of designation between them to require the 40, 45, and 401, perhaps its just that they ran out of numbers in 40xx and moved on to 45xx, then to 401xx? |
electri-fire
G2 patch files: 4
Posted: Mon Mar 01, 2010 2:52 pm Post subject:
Subject description: CMOS CV controlled oscillators |
CMOS CV controlled oscillators: I've seen schematics, will post later if someone's not faster.
In the mean time; CD4046 PLL. XR2006 . Voltage to LED to LDR (diy vactrol) .
Nice: have DA converter (maybe like DAC0808, obsolete, but that's good for diy. i have them, but not tried yet)
R/2R DAC: Inventor's "four oscillator lunetta" is an example of 4 CMOS oscillators into a R/2R DAC (digital to analog converter).
If you probe the circuit with a LED and it pulses light in the appropriate way, you can attach an LDR to the LED and use the LDR as the resistor in another R/C timed oscillator. think Thingamagoop etc. |
