 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
MIDI channels & hardware
Page 1 of 1 [2 Posts]
laura woodswalker
Audio files: 10
PostPosted: Sat Jun 12, 2010 6:16 am    Post subject: MIDI channels & hardware Reply with quote  Mark this post and the followings unread
OK this is about the dumbest question you'll see, it's about MIDI 101.
I know basically how MIDI works in applications like Reason. But I'm not sure about using it with hardware.
The electribe sequencer has 5 synth buttons and a bunch of drums. I ran a MIDI cable from the electribe to an Alesis Micron. The result was that the 1st synth channel on the Electribe played with sounds from the Micron. OK, I understand that the signals were being sent on MIDI channel 1.
Now, how would I send OTHER Midi channels? It seems that synths & keyboards can only receive one channel.
I seem to be missing a piece of information here. Is there some kind of MIDI signal splitter or mixing board to enable sending more than one channel?
Suppose I wanted to route ALL of the electribe synth channels to some other piece of hardware? Preferably, 'zones' on a keyboard. Question
laura
The most important music equipment is what's in front of the instrument.
rAC
PostPosted: Fri Dec 31, 2010 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
spend abit of time looking through thelins from http://www.midi.org/aboutmidi/forums.html
