circuit for dual output LFO with 180 degree phase shift?
Page 1 of 1 [7 Posts]
ALAS
PostPosted: Wed Aug 13, 2014 6:29 am    Post subject: circuit for dual output LFO with 180 degree phase shift? Reply with quote  Mark this post and the followings unread
I am looking for a (hopefully fairly simple) LFO circuit that would output two waveforms 180 degrees apart.
Also a possibility: a circuit for inverting the output of an initial LFO.
Also a possibility: a circuit for phase shifting the output of an initial LFO
I found a fairly simple circuit that gives you three 120 degrees apart
(http://www.schmitzbits.de/triphase.html)
and I know that quadrature LFOs also exist. For example, I found this one (http://yusynth.net/Modular/EN/QUAD-LFO/index.html)
which seems really cool and does indeed contain LFOs 180 degrees apart, but is more complicated than what I need.
Can anybody point me towards a dual version?
thermionicjunky
PostPosted: Wed Aug 13, 2014 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Inversion is a simple solution that will do exactly what you want.
Audio files: 15
PostPosted: Wed Aug 13, 2014 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Depends on the waveform..... Sine, Triangle, Square? Definitely.
Ramp/Saw, pulse? Not so much....
ALAS
PostPosted: Wed Aug 13, 2014 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be happy to just use symmetrical waveforms and invert them. I don't know how to find an appropriate circuit to do the inverting though-- I'm not exactly sure what to search for even. Any examples?
Audio files: 15
PostPosted: Thu Aug 14, 2014 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Run it through an inverting op amp:
make the two resistors the same (say, 20K or so) and you have unity gain and an inverted signal. Op amps require a bipolar supply (most of the time, there are ways around that but can get more difficult to work with audio signals).
gdavis
PostPosted: Fri Aug 15, 2014 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
http://yusynth.net/Modular/EN/LFO/VC-LFO1.html
Includes an inverted output.
okelk
PostPosted: Thu Sep 04, 2014 3:01 am    Post subject: Reply with quote  Mark this post and the followings unread
have a look at this thread:
http://electro-music.com/forum/topic-32372.html
pick any lfo ( I really like the 8k lfo...don't forget the decoupling caps), put the opamp inverter mentioned above on the output(s), add led drivers to taste ( http://www.electro-music.com/forum/topic-49449.html ) and you have what you need.
