sample class
Page 1 of 1 [5 Posts]
jirko
PostPosted: Thu May 06, 2010 8:56 am    Post subject: sample class Reply with quote  Mark this post and the followings unread
Hi there,
I've made a small sample class for overloading. The class is working so far, but when I try to load two sample at the same time only one of them plays.
Sure I'm missing something here:
Code:
"filenpath" => string file_1;
"filenpath" => string file_2;
class sample
    SndBuf sam_one => ADSR sam_one_env =>dac;
    sam_one_env.set( 1::ms, 200::ms, 0.75, 200::ms);
    fun void sample_trigger(string file, float rate, int duration)
        sam_one.pos(0);
        sam_one.rate(rate);
        file=>sam_one.read;
        sam_one_env.keyOn(1);
        duration::ms=>now;
        sam_one_env.keyOff(1);
sample SF;
spork~SF.sample_trigger(file_1, 1, 200);
spork~SF.sample_trigger(file_2, 1, 200);
2::second=>now;
vrachnasormora
PostPosted: Thu May 06, 2010 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you need two instances of sample class in order to load two different sounds because you have only one SndBuf object used by the class
Andreas
jirko
PostPosted: Thu May 06, 2010 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andreas,
maybe I'm miss understanding the way a class works, but if your're in right, where is the goal making a non public class?
What I want to do is just to create an object and call them with different parameters, without the need to rewrite the code again and again..
thanks!
Audio files: 26
PostPosted: Thu May 06, 2010 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just create two sample objects, say SF and SF1.
I think you could code:
sample SF, SF1;
spork~SF1.sample_trigger(file_2, 1, 200);
jirko
PostPosted: Thu May 06, 2010 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, that's it! thanks a lot!!
Niio1
