deadbeat
Posted: Thu Jan 26, 2012 12:37 pm Post subject:
questions about the way to build a modular lunetta.. Subject description: .. and also about the way you build mixers for lunettas modules |
Hi Everybody !
After having building some boolean sequencers, i'm starting building a big unit.
I begin with a rythmic one based on :
-1 cd40106 ( 6 osc with switchable frequencies)
-1 cd4040
-2 cd4094
-2 cd4030
-1 baby 8 sequencer
- some more cd4017stuff.
each output will be led added, and i'll put pulldown resistors on each input.
I was wondering if i can use two or more times a same output ( for example, can i fed a cd4030 input and the 4017clock input from the same cd4040 output ? Should i have to put a resistor to each cd4040's output before using them for several logic input ?).
My second question is about the way you mix your final outputs : Do you use same value resistors or is there another method ?
( for the moment, i connect all the outputs i want to 100k resistors, and all these resistors goes to a 741 input before amplification)
If i want to have one audio output and a cv output from the same logical output, what should i do ? For the moment, i use R2R ladder, am i right ?
MMM a lot of questions, i'm testing that these days... but i haven't seen yet a mixer related topic, and when i'm wathcing schematics or videos, it's not specified...
thanks for any help ! _________________ http://h.a.k.free.fr/
http://virb.com/dead_beat
http://virb.com/bend_over_boysfriends |
Draal
Joined: May 18, 2010 Posts: 291 Location: Oak Park, IL
Posted: Thu Jan 26, 2012 1:03 pm Post subject:
Lots of questions young padawan. You don't need resistors on any outs of the 4040. i use stacking banana cords and frequently use the same out to control other chips.
As for mixers, check out one of my earliest posts regarding this subject. I went with the schematic on the 2nd page of that thread and have been happy with the results. http://electro-music.com/forum/topic-42776.html&postorder=asc
Ah, memories...so innocent back in those days. Now i'm afraid I have been corrupted by these experiments ! _________________ Zontar Prevails! |
deadbeat
Posted: Thu Jan 26, 2012 1:48 pm Post subject:
Yeah, thanks Draal !!
i'm working on a big project, i'm trying to put in it all what i've already learn and understand... but it's not always easy !
i want to document it the best i can... schematic, researches notes... i'll post it there !
And another question : in order to skip static noises from my stuff, i have to put 2 1000uf caps btw vdd & vss on my breadboard ( i"m powering it with a dc 12v unit), is it normal ? How should i do for having less noise ? Ah, i've already put caps btw each V+ pin and ground for all my ics.... _________________ http://h.a.k.free.fr/
JingleJoe
Joined: Nov 10, 2011 Posts: 789 Location: Lancashire, England
Posted: Fri Jan 27, 2012 6:12 am Post subject:
| deadbeat wrote: |
And another question : in order to skip static noises from my stuff |
Static and electric noise intereference are two different things. I feel it is important a distinction is made between them because one is only slightly annoying if you want a clean signal and the other frys your chips.
getting back to your questions, one cmos output can drive 50 other cmos inputs (or so I am lead to believe, google for the datasheets of your chips and check thier fan-out to see how many other chips one output can connect to)
Audio and CV are two very different things too, they should be totally separate in the circuit anyway, then you can just tap them where you want with a voltage follower/buffer. _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Green Dungeon Alchemist Laboratories |
deadbeat
Posted: Fri Jan 27, 2012 10:50 am Post subject:
thanks jingle joe. Sorry for my english, i wanted to speak about electric noise interference... no static one. I try to do my best when i'm writting here... uhuh
Thanks again about the fan out. I didn't know that... great information, new knoledge learned, great !
Next week i'll try to spend more time on my computer to draw some schematics !! _________________ http://h.a.k.free.fr/
