  bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » Nord stage
nordstage classic and external synth korg R3
Page 1 of 1 [3 Posts]
qpw
PostPosted: Mon Jun 21, 2010 1:05 pm    Post subject: nordstage classic and external synth korg R3
Subject description: cannot figure out how to use the "external" section on Stage to control the R3
Hi
I have read the Nord Stage manual and the Korg R3 manual. But I cannot figure out how to manage the R3 trough the external section on the Nord.
I have chosen the same midi channel on both the machines. When I have the "external" section active on the Nord, no sound comes from the Korg. But the sounds is there when I have the "Piano" section active on the Nord.
Solution, anyone?
Thanks in advance.
P
alcools1
PostPosted: Wed Jun 30, 2010 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
You said that you have choose the same midi channel, but maybe not at the good place. You have to choose the same channel in the "EXTERNAL SECTION" (shift and push the 4th button).
If it work with the piano section active, it's because your Korg is using the same midi channel than the piano section (each section control a channel, for the Panel A and the Panel B).
I'm french, so , sorry for the grammatical mistakes.
qpw
PostPosted: Sun Jul 11, 2010 11:18 am    Post subject: thanks for the tip. It helped! Reply with quote  Mark this post and the followings unread
Best regards,
Peter
mps board
