MIDI File batch process in Sonar 6 Producer edition
Cubentrix
PostPosted: Wed Jul 21, 2010 6:57 am    Post subject: MIDI File batch process in Sonar 6 Producer edition Reply with quote  Mark this post and the followings unread
Hello everyone,
I am trying to export a whole bunch of midi files from Sonar 6 Producer edition in order that I may use the files in other programs. It appears that Cakewalk has a function called "Export MIDI Groove Clip." However, they don't seem to have a MIDI file export. What I have done previously is selected each individual track and copied that to a new project and then saved it. This seems to work, however, it takes a long time to do that with so many files. Is there any sort of batch process so I can export all the MIDI files in a project at one time into their own respective files. In addition to this, what is the preferred MIDI file format? I have been told that MIDI type 1 is the best. Any insight or commentary you may have is certainly appreciated. Thanks.
