Standalone Ambiophonic Audio Player & Transcoder
Page 1 of 1 [9 Posts]
shotto
PostPosted: Thu Jan 14, 2010 2:04 am    Post subject: Standalone Ambiophonic Audio Player & Transcoder Reply with quote  Mark this post and the followings unread
I'm a newbie to the forum and like to advertise two JAVA programs which I developed to allow Linux, Mac and Windows users to listen to Ambiophonics.
There are already a lot of great solutions in the forum, but I thought it would be probably useful to have some free JAVA-Apps at hand to use Ambiophonics on any operating system which supports JAVA.
I'm very much interested in your feedback, especially regarding sound quality and usability.
1.) Ambiophonic Audio Player: http://www.hotto.de/software/ambiophonicaudioplayer.html
The app opens wav audio files of the format 16Bit/44.1kHz and applies a modified version of RACE. Please refer to the web page which describes all functions in detail.
2.) Ambiophonic Transcoder: http://www.hotto.de/software/ambiophonictranscoder.html
Whereas the Audio Player is limited to wav files the Transcoder can take any signal from the input mixers including "What-U-Hear" (Stereo Mix).
If you use two soundcards or virtual mixing devices then you're able to connect your favorite audio player (e.g. iTunes, foobar2000, ...) to the transcoder which sends the signal to the selected output mixer (device).
Furthermore, you could connect a CD player via SPDIF-IN or an iPod, LP via LINE-IN to apply ambiophonics to your existing music collection by connecting the computer sound card output (e.g. SPDIF-OUT or LINE-OUT) to your HiFi equipment.
I hope both apps are useful for you.
durwood
PostPosted: Sat Feb 06, 2010 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello, I like your site. The description is very nice and clear. I especially like this:
Key advantages in comparison to stereo by playing the same material from CD, LPs or your computer:
1.) Elimination of Comb filtering effects and pinna direction finding errors
2.) By having the speakers close together reflections by walls and the bass mode response of the room are much easier to control
3.) The center presence is very stable and therefore always easy to locate
People under-estimate how closely this resembles the usefulness of mono or a centrally located speaker especially in small rooms.
This is what I found when listening to the left/right/center track from this site. The sides are stronger than the center with center set to zero. If I turn center up to 100% it is closer to being the same and the response sounds similar between sides and center but some width is lost. I had some other thoughts but trying to figure out how to best describe it. Maybe later I will have more feedback. It is similar but not exactly the same as the VST available here but they do have some differences. I'll try to sort them out later if I can.
shotto
PostPosted: Thu Feb 11, 2010 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello durwood,
I've implemented the algorithm in a way that a higher center value reduces the cross talk cancellation of signals that are equiphase and of similar amplitude. That puts an emphasis on the mono signal.
Just yesterday I've uploaded the four channel version 1.0 of the Ambiophonic Transcoder which provides the following options:
1.) 2 Input- and 2 Output-Channels to apply standard RACE on stereo material
2.) 2 Input- and 4 Output-Channels to expand 2 channel stereo to 4 channel Ambiophonics
3.) 4 Input- and 4 Output-Channels to convert multi channel source material (e.g. Dolby 5.1) into 4 channel Ambiophonics
Download: http://www.hotto.de/software/fourchannelambiophonictranscoder.html
poldus
PostPosted: Tue Jun 29, 2010 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Stephan: I am using your transcoder for music but use the VST plug-in to watch dvd´s because, unlike the VST, the transcoder delays the audio noticeably even when the smallest buffer is used, creating lip-sync issues.
Overall, I prefer your transcoder though (operating over the whole frequency range) because it manages to expand the higher frequencies along the stage with the rest of the range, rendering a more satisfying experience.
With the VST plug-in I hear highs mostly where the speakers are, so cymbals for example always seem to come from the center, regardless of their position in the recording. This happens regardless of the knob settings. I guess this could be a result of it not operating over the higher range? I will ask on their thread and see if others have heard this.
So congratulations on your implementation and thanks again for making it available to everyone.
shotto
PostPosted: Wed Jul 07, 2010 12:51 pm    Post subject: VST-Plugin Reply with quote  Mark this post and the followings unread
Hi Poldus,
I've just created an Ambiophonic VST-Plug-In on JAVA-Basis. So, it would be great if you could test it as well:
http://www.hotto.de/vstplugins/vstambiophonictranscoder.html
shitso
PostPosted: Wed Jul 07, 2010 2:33 pm    Post subject: Delay setting Reply with quote  Mark this post and the followings unread
Hi Stephan,
the plugin works fine but delay settings are not stored. Delay defaults to 70us after reloading the plugin or restart of audiomulch vst-host..
poldus
PostPosted: Mon Jul 12, 2010 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Stephan, my computer fails to load the file with new plugin. I will try again.
poldus
PostPosted: Fri Aug 13, 2010 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Still can´t open the Java based transcoder. Java is supposed to be installed in my computer (it appears in the programs listing)but there is no icon to be seen anywhere. I use a program called savihost to run electromusic´s VST application. Stephans`s requires both VST and Java? I´m a bit confused. Any ideas how I can make it work?
poldus
PostPosted: Sun Oct 10, 2010 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Disregard my previous post. I have been using the Java transcoder all along but was not aware of it!
There is one issue: With all parameters identical, in 4:4 mode the sound in the front speakers is different from 2:2, showing a lack of high frequencies and a muddy sound. So the four channel transcoder is unusable as it is. Could you please check this? Note: I´m using the 20 to 4khz. limited crosstalk feature.
Niio1
