 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
Any Midivox users out there?
Page 1 of 1 [5 Posts]
Billious
PostPosted: Sun Aug 29, 2010 5:43 pm    Post subject: Any Midivox users out there? Reply with quote  Mark this post and the followings unread
I'm hoping there's a Midivox user out there who can help me with this problem. I've recently managed to get a MidiVox. It seems to be working, but it's still behaving strangely.
It has 2 output modes: (1) following every pitch nuance of your voice by using pitch bend messages, and (2) quantizing to the nearest note to what you've sung. I would've thought that in the 2nd mode there'd be no need for *any* pitch bend messages, but it always transmits stacks of them, creating a warble in what should be a steady note.
Is this normal behaviour, or is it faulty?
Cheers, Bill
Audio files: 151
PostPosted: Thu Sep 02, 2010 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know anything about the midivox, but your post caught my attention. I tried looking for an online manual, but most of the ones google found were for accordians. I did find: http://www.healingmusic.net/MidiVoxQuotesFrame1Source1.htm#MidiVox%20Tech%20Specs
I assume this is what you have. I took a quick look and it would seem that a device like that would be putting out a ton of PB info. As I understand it, you use it to convert vocal pitch to midi pitch. If so, every time the vocal pitch changes in the slightest, new data would be transmitted (in mode 1). I would also assume that in quantize mode, the output would be note data only (unless you can fine tune it to any pitch, in which case I would expect to see rounded PB data).
Is there any difference at all between the output in the two modes? I suppose if I had one of those, I would measure the change in PB data. In the quantize mode is the data rounded at all while in the non-quantize mode is the data not rounded?
Again, I have no experience with this, but it looks very interesting!! I would like to see it in operation.
--Steve
PS: Do any of the review articles address the issue you raise? BTW, for $1295 list, I think you should ask the manufacturer.
Billious
PostPosted: Sat Sep 04, 2010 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
G'day Steve, thanks for replying. Sorry for taking so long to answer you.
Yep, that's how I understand it too.
I haven't examined it that closely, but the fact that it's outputting pitch bend data at all whilst in the "quantized" mode makes me think now that it's faulty.
I've been very interested since they were first released in '92. I managed to get this one on eBay with a friend. Hopefully, if we get it working and you happen to be passing through Geelong, Australia, you're most welcome to see it in operation. Smile
Haven't read all the reviews, but I will ask the manufacturer - AFAIK that's now Healing Music - how I'd go about getting it repaired.
Cheers, Billious
Audio files: 151
PostPosted: Sat Sep 04, 2010 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about when you get it working and have some music to play with it, you can demo it on the Open Port here, preferably with a webcam, too? In any case, hope you can get it working the way it should soon.
--Steve
Billious
PostPosted: Sat Sep 04, 2010 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd love to. Smile
Thanks for your good wishes, Steve. Happy music-making!
