<on air> Onewayness and Cynosure Live Jam from Cynostudios
....and another metallic sound
davep
Audio files: 10
G2 patch files: 73
PostPosted: Tue Feb 01, 2005 12:18 am    Post subject: ....and another metallic sound Reply with quote  Mark this post and the followings unread
Hi all,
Here's another variation. This one uses a pair of shape oscs with just a bit of motion. The shape never gets too bright, though. This is to prevent aliasing distortion, which can otherwise occur pretty easily in patches that use ring modulators.
Each osc goes through a pair of multimode filters in 6dB "peaking" filter mode, so these filter peaks sweep thru the harmonics of the oscs. Then these signals with sweeping harmonic peaks go into the ring modulator, for the cool wave-table-y metallic sweeping sound. Then the usual phasers & filters & warmth filters.
I'm trying different ideas with the reverb module to dress it up a bit. This one uses two reverbs with different settings and different pre-delays, and one has a bit of delay modulation, and these two reverbs are panned slightly L & R. Enjoy!
Alien Bells3.pch2
 Filename:  Alien Bells3.pch2
 Filesize:  5.63 KB
 Downloaded:  938 Time(s)
Dave Peck
