FaschingsPrinz
G2 patch files: 4
Posted: Sat Sep 25, 2010 2:49 am Post subject:
G2 Mutator-window vanished ? |
Hello friends,
I´m completely new to this forum and the G2 too.
I bought mine (used) a few days ago
Since then, I´ve been fooling around with it a lot (of course).
Due to the reason that I´m running the G2-editor on my Thinkpad x60 (sub-notebook) which has only a resolution of 1024x768 I have connected an external Monitor to it running on a higher resolution, so I will be able to see more modules and also the overview of the knob-assign-window.
I use the monitor as a desktop-extension.
Since I´ve done that unfortunately my patch-mutator-window vanished and does not appear when I call it from the pulldown or try to start it with CTRL-2.
The patch-mutator-window seems to lay now somewhere outside the borders of my display.
To get rid of it I would like to delete the file which stores the window-positions of the last editor-session.
Could anybody please help me identify which file it is that holds the Gs-window-positions.
Thanx a lot in advance, _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
But if I have an idea, and you have an idea, and we exchange ideas, then we BOTH have TWO ideas."
G.B.SHAW |
Joined: Apr 03, 2004 Posts: 19621 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Sep 25, 2010 4:57 am Post subject:
Under Vista it is in :
c:\Users\<username>\AppData\Roaming\Clavia\Modular G2 editor.pref
where AppData is a hidden folder, so you may have to enable viewing hidden files.
Under XP it is in c:\Documents and Settings\<username>\Application Data\Clavia\Modular G2 editor.pref
The pref files are text, so you can edit in it too if you like. _________________ Jan |
FaschingsPrinz
G2 patch files: 4
Posted: Sun Oct 03, 2010 8:10 am Post subject:
.. just in case, somebody else is going to have this or a similar problem, I´ve been able to solve the problem thanx to blue hells advice.
The file can also be found, when searching your disk for files with a recently changed date, because it´s written every time when closing the editor.
So after closing the editor it´s one of the most recent changed file on your disk.
This solved my vanished-window issue.
Thanx a LOT! _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
G.B.SHAW |
