<on air> bingsatellites Mostly Ambient
Problem with 10 step sequencer
Page 1 of 1 [4 Posts]
Ohmu
PostPosted: Thu Jul 30, 2009 4:13 am    Post subject: Problem with 10 step sequencer
Subject description: how to use with 9v battery?
Hi! I have just finished my 10 step sequencer from mfos, but i have a little problem with the explanation : how to do 12v ou 15v with one or more 9v battery. On mfos website nothing explain how to power the sequencer. Does anyone can help me? Thank !
skylab76
PostPosted: Sun Aug 02, 2009 11:30 am    Post subject: Re: Problem with 10 step sequencer
Hi Ohmu ,
Take a look at :
http://electro-music.com/forum/viewtopic.php?highlight=battery&t=33836
It mentions how to set up +/- 9V from 2 9V batteries based on a suggested configuration from soundlab.
OR you can wire 2 of these the same way using AA batteries to make +/- 12V. I did that for a while until I got 12 V PSU.
I hope this helps.
Regards
spitfire
PostPosted: Thu Jan 06, 2011 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone. First message for me in this forum. I happy to be a new user here, I think there's about two people in my country doing analog things, so this forum is heaven Smile
I made MFOS 10step sequencer, everything works fine, accept little problem with third step, it doesn't work at all, giving nothing at CV output. I checked many times, don't see that wires are not connected or smth. I also changed the tranzistor 2N3904, still doesn't work. I connected it as a first step and LED flashes, and I can control CV output with trimmer.
Can it be that CD4017 chip broke at only one pinout inside ? I don't think so.
I hope I wrote clear.
Thanks.
-minus-
PostPosted: Tue Jan 18, 2011 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might want to swap that 4017 for a new one. Did you use IC sockets? Makes it easier when chips need replacing. If you still have the same problem you need to look at the wiring coming from the step 3 pin which is PIN 7 on the 4017 I believe.
If the transistor will function with a different step activating it, then there is a problem with Pin 7. If you used a socket you might want to check that the legs are all in the socket correctly and pin 7 is not bent (easy to have this happen). Reheat the solder on pin 7 just incase you have a cold solder joint there.
You must be close to having this working. I just looked at that sequencer. It's got a few components! Are you building it on one of the MFOS boards?
Good luck!
Niio1
