EFOs
iPassenger
G2 patch files: 78
PostPosted: Fri Dec 10, 2010 8:24 am    Post subject: EFOs
Subject description: More Custom LFOs from Envelopes
I had this idea this morning that by using the compare to signal level module you could turn any of the envelopes into a lfo. Attached is patch which has the more obvious way of using the ADR module with its handy end gate output and one created using the AHD mdoule so you can create repeating trapezes.
Pretty obvious so apologies if you all know this one already. Smile
EFOs.pch2
 Filename:  EFOs.pch2
 Filesize:  2.79 KB
 Downloaded:  363 Time(s)
iP (Ross)
